Hello! Does somebody use XL1278 LoRa module? I cant put in sleep mode - the current doesn't drop from 20 mA after LoRa.sleep();
This is the diagram:
And the code:
#define codeVersion "arduino_pro_mini_low_power_lora_send_2023_03_26"
#define compilationDate __DATE__
#define compilationTime __TIME__
#define analogInput A0 // 12V, 1.27V, av=12109
#define deepSleepTime 60 //MCU deep sleep time,sec
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <SPI.h>
#include <LoRa.h>
int av, at;
// watchdog interrupt
ISR (WDT_vect)
wdt_disable(); // disable watchdog
} // end of WDT_vect
void setup ()
while (!Serial);
Serial.println("Setup start...");
Serial.println(codeVersion);
Serial.print("Compilation date: ");
Serial.println(compilationDate);
Serial.print("Compilation time: ");
Serial.println(compilationTime);
if (!LoRa.begin(433E6))
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("... Setup ready");
void loop ()
Serial.println("loop start");
/* for(int i=0;i<1;i++)
Serial.print("Start analog reading after ");
Serial.print(10-i);
Serial.println(" s");
delay(999);
av=0;
at=0;
for(int i=0;i<20;i++)
at=analogRead(A0);
av=av+at;
Serial.print(i);
Serial.print(" ");
Serial.print(at);
Serial.print(" ");
Serial.println(av);
delay(999);
// send packet
LoRa.idle();
LoRa.beginPacket();
LoRa.print(av);
LoRa.endPacket();
Serial.println("LoRa send end");
LoRa.end();
LoRa.sleep();
Serial.println("mcu deep sleep start");
for(int i=0;i<deepSleepTime/8;i++)
// disable ADC
//ADCSRA = 0;
// clear various "reset" flags
MCUSR = 0;
// allow changes, disable reset
WDTCSR = bit (WDCE) | bit (WDE);
// set interrupt mode and an interval
WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0); // set WDIE, and 1 second delay
wdt_reset(); // pat the dog
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
noInterrupts (); // timed sequence follows
sleep_enable();
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
interrupts (); // guarantees next instruction executed
sleep_cpu ();
// cancel sleep as a precaution
sleep_disable();
Serial.println("mcu deep sleep end");
