Hi all, I have a problem regarding "LoRa multiple communication" on ESP32.
I am doing a project with 3 wifi sniffer nodes as 3 slaves. They will always be active, keeping sniffering/listening to the nearby packets data. They send the data to the server only when a specific request has been sent by the master. The workflow will be like: master send requests to slave 1 and wait for answer from slave 1 at 0~1s. When the slave 1 got the request, it will send the data to the server. Same applies to slave 2 and 3 in every second afterwards.
My problem is that not every request sent by master will be answered by the specific slave. I.e., it might request 5 times and only got 1 response, like the picture below. Also, the program became blocked forever when around 32 packets have been set to the master (Not sure if it's relevant to LoRa.endPacket())
The (part of) master code is:
loop()
if (millis() - lastRequestSentTime > 500)
if (turn == 1)
SendRequest("1#"); // Send request to Client 1
receiveFromSlaveDevice("1#"); // This is data from Client 1
lastRequestSentTime = millis();
// trun = 2;
// contintues to turn 2 and 3
vTaskDelay( 100 / portTICK_PERIOD_MS );
void SendRequest( String request )
LoRa.beginPacket(); // start packet
LoRa.print(request); // send request
LoRa.endPacket(); // finish packet and send it
} // SendRequest
void receiveFromSlaveDevice( String nodeID )
int packetSize = LoRa.parsePacket();
if (packetSize)
Serial.println( "Received packet from: " + nodeID );
String incomingMessage = ""; // payload of incoming packet
while ( LoRa.available() )
String incomingMessage = LoRa.readString();
// incomingMessage (WiFi device data) format: Timestamp \t MAC Address \t RSSI \n
int pos1 = incomingMessage.indexOf('\t');
int pos2 = incomingMessage.indexOf('\t', pos1 + 1);
int pos3 = incomingMessage.indexOf('\n', pos2 + 1);
std::vector<String> wifiDevicePayload(3);
wifiDevicePayload[0] = incomingMessage.substring(0, pos1); // Timestamp
wifiDevicePayload[1] = incomingMessage.substring(pos1 + 1, pos2); // MAC Address
wifiDevicePayload[2] = incomingMessage.substring(pos2 + 1, pos3); // RSSI
Serial.println("Index 1: " + wifiDevicePayload[0]);
printWiFiDeviceData( wifiDevicePayload );
xQueueSend( g_queueBetweenReceiveAndWebServer, &wifiDevicePayload, portMAX_DELAY );
The (part of) slave code is:
if (packetSize)
String request = LoRa.readString();
if ( request == "1#" )
Serial.println( "Client 1 got request, answering Server..." );
sendToMasterDevice( WiFiDeviceData );
Serial.println( "ERROR - No requests from Server." );
It seems there is some transition time needed for the LoRa chip to switch from sending mode to receiving mode. But there is not a function can be used to wait until a message is received... (Like
RF95.waitAvailableTimeout()
in RadioHead Library, RadioHead: RHGenericDriver Class Reference).
I was mainly refering to this: https://miliohm.com/multi-clients-lora-with-a-server-communication/. And I wonder if it is possible to achieve the same thing by using arduino-LoRa library (GitHub - sandeepmistry/arduino-LoRa: An Arduino library for sending and receiving data using LoRa radios.)
Any suggestions or ideas will be of highly appreciated! Many thanks!
