LoRa on Arduino Uno Rev2 but unable to on Uno Rev2 with WiFi
Ran into an issue with an IoT project that I am working on. Using REYAX RYLR896 LoRa modules between a nano and an Uno I send sensor data using our rev2 (without WiFi) and can receive and send and use AT commands seamlessly. When I switch to a rev2 with WiFi I can no longer receive data from my LoRa module. I assume it has something to do with power delivery to the module because of the WiFi chip but am unsure of how to fix the issue. The module communicates through the serial port and uses the 3.3V rail. Let me know if there is a way to get this thing to receive on the rev2 with WiFi as I am stumped.
Please post your full sketch.
If possible, you should always post code directly in the forum thread as text using code tags:
  • Do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code. This will make it easier for you to spot bugs and make it easier for us to read.
  • In the Arduino IDE or Arduino Web Editor, click on the window that contains your sketch code.
  • Press "Ctrl + A". This will select all the text.
  • Press "Ctrl + C". This will copy the selected text to the clipboard.
  • In a forum reply here, click the "Reply" button.
  • click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the sketch between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Repeat the above process if your sketch has multiple tabs.
This will make it easy for anyone to look at it, which will increase the likelihood of you getting help.
If the sketch is longer than the 9000 characters maximum allowed by the forum, then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link that will allow you to make the attachment.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
Please tell us exactly how the REYAX RYLR896 is connected to the Uno WiFi Rev2.
