Greetings, I'm attempting to receive a packet using LoRa, before displaying it on my LCD screen followed by another screen showing some dummy values.
I'm using a Dragino LoRa Shield to send and transmit, an ST7920 LCD to display and an ESP32 Devkitc V4 and a microcontroller.
The basic receiving code works alone, (based on this tutorial from Random Nerd Tutorials), but as soon as I include the code to display some dummy temperature values on my LCD, I never receive any packets consistently, the intervals seem random.
Is this something to do with the delay included in the code? I use this as a timer for each LCD 'slide'. My transmitter code sends a packet every 10 seconds.
String LoRaData;
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
LoRaData = LoRa.readString();
Serial.print(LoRaData);
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
// If a message is intercepted, write the LCD screen to high and write out what it says
digitalWrite(hspi->pinSS(), LOW); //enable CS on LCD to write to via HSPI pins
u8g2.setFont(u8g2_font_unifont_t_chinese2); // use chinese2 for all the glyphs of "你好世界"
u8g2.setFontDirection(0);
u8g2.clearBuffer();
u8g2.setCursor(25, 15);
u8g2.print("Receiving:");
u8g2.drawUTF8(0, 50, LoRaData.c_str()); //write String
u8g2.sendBuffer();
digitalWrite(hspi->pinSS(), HIGH); //disable
delay(7500);
//delay(3000);
// DISPLAY TEMPERATURE AND HUMIDITY
int temperature = 15;
int relative_humidity = 20;
// Display Data recieved via temperature and humidty sensor
u8g2.setFontDirection(0); // set font to be written along x plane
u8g2.clearBuffer(); // clear memory so that LCD can be written to
u8g2.setCursor(1, 15); // set cursor at desired location x = 15, y = 15
u8g2.print("Temperature"); // Print 'Temperature'
u8g2.setCursor(15, 30); // Set starting point on x = 15 and y = 30 BEGINS TOP LEFT
u8g2.setFont(u8g2_font_sonicmania_tr); // Set font
u8g2.print(temperature); // Print temperature value
u8g2.setCursor(52,23); // Print the celsius unit
u8g2.print(".");
u8g2.setCursor(55,30);
u8g2.print("C");
u8g2.setFont(u8g2_font_lubBI10_tf); // set font
u8g2.setCursor(1, 45); // set font to be written at x = 1, y = 45
u8g2.print("Relative Humidity");
u8g2.setCursor(15, 60);
u8g2.print(relative_humidity);
u8g2.setCursor(45, 60);
u8g2.print("%");
u8g2.sendBuffer();
delay(5000);
