I have created a LoRa sender node and a receiver.
When I power up both sender and receiver at a time, the receiver started receiving packets and serial monitor prints the received data as expected.
But when I switch off the sender node and switch it on after few seconds, no received data is shown in Serial Monitor. Communication is happening again normally, when I press reset button of the Receiver. Please correct me if anything is wrong and suggest a solution to address this issue.
HW Used:
Sender Node: ESP32-WROOM-32 (ESP32-DevKitC) and SX1278(Ra-02) LoRa module with spring type antenna
Receiver: ESP32-WROOM-32 (ESP32-DevKitC) and SX1278(Ra-02) LoRa module with spring type antenna
Code: Sender
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
//define the pins used by the transceiver module
#define ss 5
#define rst 14
#define dio0 2
int counter = 0;
//initialize Serial Monitor
while (!Serial);
Serial.println("LoRa Sender");
LoRa.setPins(ss, rst, dio0);
while (!LoRa.begin(433E6)) {
Serial.println(".");
LoRa.setSyncWord(0xF3);
Serial.println("LoRa Initializing OK!");
sendpacket();
delay(2000);
void sendpacket()
Serial.print("Sending packet: ");
Serial.println(counter);
//Send LoRa packet to receiver
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
delay(5000);
Code: Receiver
#include <SPI.h>
#include <LoRa.h>
#define ss 5
#define rst 14
#define dio0 2
while (!Serial);
Serial.println("LoRa Receiver");
// register the receive callback
LoRa.onReceive(onReceive);
// put the radio into receive mode
LoRa.receive();
void loop() { }
void onReceive(int packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
for (int i = 0; i < packetSize; i++) {
Serial.print((char)LoRa.read());
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
