Lora receiveresp32 to esp8266
Hi there, i have a question
i’m trying to send data to an esp8266 from my lora esp32 receiver, how i do that?
esquematic
adlx345 —> lora esp32(Sender)-----> lora esp32(Receiver) (works)
so now i’m trying to do this.
adlx345 —> lora esp32(Sender)-----> lora esp32(Receiver)---------->esp8266
lora receiver code…
/Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
#define BAND 866E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
String LoRaData;
  //reset OLED display via software
  pinMode(OLED_RST, OUTPUT);
  digitalWrite(OLED_RST, LOW);
  delay(20);
  digitalWrite(OLED_RST, HIGH);
  //initialize OLED
  Wire.begin(OLED_SDA, OLED_SCL);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.setCursor(0,0);
  display.print("      Lora Recetor ");
  display.display();
  //initialize Serial Monitor
  Serial.println("LoRa Receiver Test");
  //SPI LoRa pins
  SPI.begin(SCK, MISO, MOSI, SS);
  //setup LoRa transceiver module
  LoRa.setPins(SS, RST, DIO0);
  if (!LoRa.begin(BAND)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  Serial.println("LoRa Initializing OK!");
  display.setCursor(0,10);
  display.println("LoRa Initializing OK!");
  display.display();
  //try to parse packet
  int packetSize = LoRa.parsePacket();
  if (packetSize)
    //received a packet
    Serial.print("Aceleracao: ");
    //read packet
    while (LoRa.available())
      LoRaData = LoRa.readString();
      Serial.print(LoRaData);
    //print RSSI of packet
    int rssi = LoRa.packetRssi();
    Serial.print(" with RSSI ");
    Serial.println(rssi);
   // Display information
   display.print("      Recetor Lora");
   display.setCursor(0,20);
   display.print("Aceleracao:");
   display.setCursor(0,30);
   display.print("X");
   display.setCursor(0,38);
   display.print("Y");
   display.setCursor(0,47);
   display.print("Z");
   display.setCursor(10,30);
   display.print(LoRaData);
   display.display();
