I am using the LoRa library by sandeep mistry. When I upload the example "LoRa Sender" code, the pro mini keeps resetting at transmission. It happens when transmitted at 433MHz.
It wouldn't happen when I reduce the tx power to 12. Has this happened to anyone else?
is 12dBm the maximum power that I can transmit using a pro mini?
are there any workarounds to fix this?
Could be that the power supply your using is just not up to supplying the required current ?
There is a common issue with 3.3V Pro Minis in that the brownout reset voltage is often set at 2.7v, which is fine for 5V Pro Minis but not really for 3.3V ones. Reprogramming the fuses for a 1.8V brownout can help.
For 433Mhz ISM band use the legal power is often restricted to 10mW.
Thank you.
I also want you to know that I am planning on using ArduinoLowPower library to put the MCU to powerdown mode.
Do you think it can conflict with me manually reprogramming brownout fuses ?
I have used a Pro Mini 3.3 with a RA-02 without problems using pins
// RA-02 SS to Pro Mini D10
// RA-02 RST to Pro Mini D9
// RA-02 DIO0 to Pro Mini D3 requires interrupt pin!!!!
// RA-02 MOSI to Pro Mini D11
// RA-02 MIS0 to Pro Mini D12
// RA-02 SCK to Pro Mini D13
// setpins() is therefore
// ***** note DIO0 requires a pin which enables interrupts, e.g. pro mini D3 *********
// setPins(int ss = LORA_DEFAULT_SS_PIN, int reset = LORA_DEFAULT_RESET_PIN, int dio0 = LORA_DEFAULT_DIO0_PIN);
// LoRa.setPins(10, 9, 3); // 10 for UNO and Pro Mini, 53 for Mega
This is the module and the antenna its a short cable around 10cm
The resetting of the board starts right after i flash the program. At that moment it is powered through the adapter.
I also have another pro mini where i have removed the voltage regulator and is powered using a MCP1700 and a LiPo battery.
when uploaded the same sketch, It sometimes runs a few loops without an issue and then gets stuck in a reset loop after a while. emphasized text
I also had freezing Nano's with Lora.h and LoRa RA 01.
The Lora.h library does not work with the Interrupt , disconnect the Interrupt pin and see if it stops working.
When I changed to LoraRF.h it never hanged up , running for a week transmitting every 10 seconds.
Is your power supply not experiencing a small voltage dip during transmission?
My power supply experiences a voltage dip of around 0.4V when transmitting at txpower(12)
Yes .. The wiring is the same as 100's of examples all over the Internet.
The exact same wiring never hang up when I change to LoraRF.h.
When I reduced the TX Power all works ok.(Using LoRa.h)
Below is my old post regarding the freezing of Lora_Nano setup.
