LoRa RF95 capture thermostat signal?
Hello ! I want to build a IoT project and I was wondering if anyone can help me out with something. At least to know if it's doable. I have a Thermostat to control the temperature that works on 866Mhz, it says so in the specifications. I also have a LoRa RF95 that works on the same frequency. Is there any way I could capture the thermostat signal? After that I want to send it back using another LoRa. I know you can send packages and make 2 Arduinos communicate between one another using two LoRa modules. I just want to "clone" the termostat signal instead.
I doubt it. LoRa's physical network layer is proprietary and complex. I'll guess that your thermostat isn't using it and is just transmitting in the clear on a single frequency. Since you have both devices, you could try it, but I would expect to get nothing at the LoRa device.
You would probably need a simpler radio to receive the signal from the thermostat which you could then retransmit using LoRa.
Theofoil:
Potentially yes.
The LoRa devices support FSK and GFSK modes as well as LoRa and a lot of sensor type devices operate using FSK type communications.
Good luck.
