LoRa RSSI with MKRWAN1310
Does anyone know how to transmit information on the quality/Signal strength RSSI on the MKRWAN1310 Arduino board?
Would appreciate any comments or suggestions on how to measure this and use it...
Thx
Bijan
If you can find a good use for RSSI values, let us know.
The MKRWAN1310 uses a standard SX1276 LoRa device.
Most LoRa libraries provide a function for returning the RSSI of the last received packet.
The signal to noise ratio (SNR) is a better indicator of how close to reception failure a packet is.
What Lora library are you using?
Look in the library's examples and see what code they have.
Thanks Tom.. :slight_smile:
