Hello. I am working on a Arduino Nano based flight computer (I would classify myself as an intermediate at Arduino ide, I know what I am doing for the most part, but there is a good possibility that I missed something obvious). I am working on ways to send data from the flight controller to the ground computer (gps position, altitude, and speed). I am currently trying to get the Reyax Rylr890 to send this data. I followed this tutorial: https://how2electronics.com/reyax-rylr890-lora-module-with-arduino/ For simplicity before I add the rylr to the rest of my project, I am currently set up with the same exact code, wiring, and hardware that the guy in the tutorial uses. Both devices are plugged into the same computer through different com ports of course, but I tried using two different computers with no change in results.
This tutorial got me to successfully send data between the two rylr890s, however, I have run into an issue that I can not figure out. The incoming data is quite often corrupted. For example:
This is the correct data:
This is the next packet I receive with incorrect data:
You can see in the corrupted packet a period is turned into a /, a space is turned into a @, and a comma is turned into a /. I live in a rural area, so there is no radio traffic, and the devices are sitting about 1m apart with no obstructions, so the issue isn't that the data is getting corrupted on the way across the two devices. If I were just reading this data, it wouldn't be an issue because I would just be able to tell which packets were correct and which were not, however, in my case, I need all the packets to be correct. The receiving data is going to be sent to an SD card once received, then from there uploaded to google sheets or a similar program. Google sheets reads commas as where to put data into the next row. If the comma is switched out for a slash or period, sheets will not put the next data into a new box which will screw up the charts. I should note that this also happened in the tutorial I followed, but he didn't seem to care.
The next issue, or rather question, I have is for my project, I have to use SoftwareSerial because the gps already takes the default tx and rx pins. I know that if you use the default tx and rx pins with the rylr890 for AT commands, all you have to do it type AT+(whatever you need) into the serial monitor and you will get a response. However, it isn't that simple with SoftwareSerial. I assumed I could just use
while (Serial.available()) {
lora.println(Serial.read()); //I have also used lora.write(Serial.read()); here
(lora being the SoftwareSerial) to put AT commands into the Serial, however, that doesn't appear to work since I get no response back. I can't imagine it is that hard of a fix, but I can't seem to figure it out.
Let me know if I missed any critical information necessary to fix my problems.
Thank you for your time!
