Using tick marks (') to enclose code on this forum does not work. If you read the forum guidelines in the sticky post, it will tell you how to post code, links, pictures and other tips about what to include in your post so that others can help you. Please modify your post above and correct it.
You have probably not connected the LoRa device correctly, but you did not provide any details of your setup or the Arduino you are using, so thats just a guess.
srnet:
Did you follow all the steps, or just the ones you wanted to follow? What about these steps:
NOTES:
Some boards (like the Arduino Nano), cannot supply enough current for the SX127x in TX mode. This will cause lockups when sending, be sure to use an external 3.3V supply that can provide at least 120mA's when using these boards.
If your Arduino board operates at 5V, like the Arduino Uno, Leonardo or Mega, you will need to use a level converter for the wiring to the Semtech SX127x module. Most Semtech SX127x breakout boards do not have logic level converters built-in.
mavericks123:
I followed all steps of connection. 3,3V is.
No, you did not follow the steps I quoted in post #7. You did not attach a proper schematic as I requested in post #5. Edit: schematic now added by OP.
Are you having difficulties with understanding technical English? There are forum sections for some other languages. Perhaps you will find it easier if you post your question in one of those sections.
PaulRB:
