Lora SendError: Length: 15 IRQreg: 57F,IRQ_CAD_ACTIVITY_DETECTED,IRQ_FSHS_CHANGE_CHANN
Hi
I have used hours trying to find my mistake.
The main part of this code is used in another project, that did work. So maybe I have missed something (previous use of code was on same hardware, V2. This is V3, has same chip/pin layout ESP32Wroom, LoRA, buzzer.
Now I have a PCB I need to test, and to get info from it when not connected to PC I need to send LoRa messages.
This is the error message
SendError:
Length: 15 IRQreg: 57F, IRQ_CAD_ACTIVITY_DETECTED, IRQ_FSHS_CHANGE_CHANNEL,IRQ_CAD_DONE, IRQ_TX_DONE, IRQ_HEADER_VALID, IRQ_CRC_ERROR, IRQ_RX_DONE, TX_TIMEOUT, NO_PACKET_CRC
Hope I can get some help with my code:.
Serial Output:
    Kompileringsinformasjon:
    Filnavn kode:D:\Arduino2024\HiveMon\PCB3_test_flip_flopp_sleep_v8_LoRa\functions.ino
    Kompileringsdato: Dec 28 2024
    Klokkeslett:      11:06:08
No LoRa start!
ModemSettings:
SX1278_PABOOST,0hz,SF0,BW7800,CR4:4,LDRO_Off,SyncWord_0x0,IQNormal,Preamble_0
OperatingSettings:
SX1278_PABOOST,SLEEP,Version_0,PacketMode_FSK,Explicit,CRC_Off,AGCauto_Off,LNAgain_0
LoRa start
  3.3 AND 5V IS NOW SWITCHED ON, DEFAULT IS floating
Choose:
  '1' B_C_Sel Default LOW=superC            Trigger (veksle mellom Bat/Cap) B_C_Sel HIGH - LOW
  '2' EN_B_CH Default LOW=LiPo no charge    Activate/deactivate LiPo charging
  '3' EN_SLP  Default LOW= 3.3 and 5V Off   3.3v on/off sensors
  'x' ESP                                   Sleep + 3.3 OG 5 v OFF
sCap ADC Value raw:      3261
sCap voltage Out (ADC):  2.628
sCap Voltage In (Real):  5.450
Status now:
'1' Pulse B_C_Sel_Status (bat or cap) : 1 = Lipo power      0 = SuperCap: 0
'2' Pulse EN_B_CH_Status (LiPo charge): 1 = LiPo charge ON, 0 = Off:      0
'3' EN_SLP_Status  (volt on / off)    : 1 = 3.3 og 5V ON    0 = Off:      1
sCap ADC Value raw:      3248
sCap voltage Out (ADC):  2.617
sCap Voltage In (Real):  5.429
Status now:
sCapADCRaw:     3245
sCapVoltageOut: 2.62
sCapVoltageIn:  5.42
B_C_Sel_Status: 0
EN_B_CH_Status: 0
EN_SLP_Status:  1
Packet:
AD 0C 00 00 76 5C 27 40 B5 8D AD 40 00 00 01
SendError:  Length: 15 IRQreg: 57F,IRQ_CAD_ACTIVITY_DETECTED,IRQ_FSHS_CHANGE_CHANNEL,IRQ_CAD_DONE,IRQ_TX_DONE,IRQ_HEADER_VALID,IRQ_CRC_ERROR,IRQ_RX_DONE,TX_TIMEOUT,NO_PACKET_CRC
// functions
void packet_is_OK();
void packet_is_Error();
void readVoltToSerial();
void PrintFileInfoAndVersion();
void setupLoRaSettings();
void handleButtonPress();
void printASCIIPacket(const uint8_t* data, size_t length);
// Include necessary LoRa library
#include <SPI.h>
#include <SX127XLT.h>
#include "settings.h"
#include <Wire.h>
SX127XLT LoRa;                            // create a library class instance called LoRa - Ai Thinker LoRa 1276 chip
// for å lese 2 siffer i filnavn (versjonsnr) +  funksjon PrintFileInfoAndVersion()
#include <cstring> #include <cstdlib> #include <iostream>
#include <esp_sleep.h> // for å sette i sleep modus
uint64_t resultSleepTime   = 0LL;         // Variabel som holder faktisk sleep time
uint64_t sov15sek          = 15LL * 1000000LL; // Første tall er sekund sov
uint64_t sov60sek          = 60LL * 1000000LL; // Første tall er sekund sov
unsigned long startTid;
bool recivedInput = false;
//unsigned long startmS = 0;  // lora variabel
//unsigned long endmS   = 0;  // lora variabel
uint32_t TXPacketCount, startmS, endmS;   // lora variabel positive int 2^32, dette er 3 variabler av samme type
// Debounce-parametre for tare/calibrate
unsigned long lastDebounceTimeTare = 0;
unsigned long lastDebounceTimeCalibrate = 0;
const unsigned long debounceDelay = 400;         // 200 ms debounce
//      Trigger and battery options
// EN_B_CH : DEFAULT LOW  --->  CHARGE DISABLE
// FIRST HIGH TO LOW PULSE : BATTERY CHARGE
const int EN_B_CH  = 26;    // EN_B_CH slår på og av LiPo lading
// Default LOW ---> CAP OUTPU
// FIRST HIGH TO LOW PULSE : BATTERY AS POWER
// SECOND HIGH TO LOW PULSE : CAPACITOR AS POWER and so on...
const int B_C_Sel          = 32;    // B_C_Sel, velge energikilde puls høy til lav
const int EN_SLP           = 27;    // EN_SLP slår av 3.3 og 5 V unntatt ESP32
const int buzzerPin           = 4;     // til buzzer
const int solPin              = 33;    // adc volt solar
const int sCapPin             = 36;    // adc volt sCap   VP=36 sCap test med LiPo
const int LiPoPin             = 39;    // adc volt LiPo   VN=39 Voltmeter LiPo with the actual analog pin number you are using
int sCapADCRaw       = 0;
float sCapVoltageOut = 0.0;
float sCapVoltageIn  = 0.0;
const int switchTare          = 34;
const int switchCalibrate     = 35;
const int switchAlarm         = 25;
bool B_C_Sel_Status           = LOW;   // Default low -> Cap On.      Variabel for å holde tilstanden til energikilde B_C_Sel
bool EN_B_CH_Status           = LOW;   // Default low -> No charge.   Variabel for å holde tilstanden til volt rail EN_B_CH
bool EN_SLP_Status            = LOW;   // Starts low to save power. Slår av 3.3 og 5 V, Variabel for å holde tilstanden til power On/Off
#define ADC_MAX 4095             // 12-bit ADC
#define ADC_REF 3.3              // Referansespenning for ESP32
#define sCapScaleFactor 2.074    // OK Kalibrert faktor basert på faktisk måling: scap 5,502, scapin 2,665 v
const float solDividerFactor  = 6.2 / 3.3;  // For solPin (1:0.53)
const float sCapDividerFactor = 5.7 / 3.3;  // For sCapPin (1:0.579)
const float LiPoDividerFactor = 4.2 / 3.3;  // For LiPoPin (1:0.785)
// Definer Payload-struct for å sende data over LoRa
//struct Payload {
// setup payload as struct Må være identisk på mottagerside
struct __attribute__((packed)) Payload {
  int   PsCapADCRaw;        // Rå ADC-verdi fra supercapacitor
  float PsCapVoltageOut;    // Spenning ut fra ADC (0-3.3V)
  float PsCapVoltageIn;     // Faktisk spenning etter skaleringsfaktor
  bool  PB_C_Sel_Status;    // Status for energikilde (Bat/Cap)
  bool  PEN_B_CH_Status;    // Status for LiPo-lading (aktivert/deaktivert)
  bool  PEN_SLP_Status;     // Status for sensorstrøm (3.3V/5V)
// #############################   VOID SETUP   ########################################
  SPI.begin();
  delay(100);
  if (LoRa.begin(NSS, NRESET, DIO0, DIO1, DIO2, LORA_DEVICE)) {
    Serial.println("LoRa start");
    Serial.println(F("No LoRa start!"));
  setupLoRaSettings(LoRa);    // Set up LoRa settings in settings.h
  Payload myPayload;         // de fleste variabler må være klare før de pakkes i myPayload som skal sendes over LoRa
  analogReadResolution(12);
  //    dette ga ikke utslag når scap var fulladet.   analogSetPinAttenuation(sCapPin, ADC_11db);  // Tillater opptil ~3.9V
  // cgatgpt foreslo dette:
  // analogSetAttenuation(ADC_2_5db);       // For 1V til 2.5V område
  pinMode(B_C_Sel, OUTPUT);  // 1 input serial
  pinMode(EN_B_CH, OUTPUT);  // 2 input serial
  pinMode(EN_SLP, OUTPUT);   // 3 input serial
  pinMode(buzzerPin, OUTPUT);
  pinMode(switchTare, INPUT);
  pinMode(switchCalibrate, INPUT);
  digitalWrite(EN_SLP, HIGH);      // switch on 3,3 + 5Vv
  EN_SLP_Status = !EN_SLP_Status;  // togle status value from default LOW (0) to HIGH (1)
  Serial.println("  3.3 AND 5V IS NOW SWITCHED ON, DEFAULT IS floating");
  //FIRST HIGH TO LOW PULSE : BATTERY AS POWER
  Serial.println("Choose:");
  Serial.println("  '1' B_C_Sel Default LOW=superC            Trigger (veksle mellom Bat/Cap) B_C_Sel HIGH - LOW");
  Serial.println("  '2' EN_B_CH Default LOW=LiPo no charge    Activate/deactivate LiPo charging");
  Serial.println("  '3' EN_SLP  Default LOW= 3.3 and 5V Off   3.3v on/off sensors");
  Serial.println("  'x' ESP                                   Sleep + 3.3 OG 5 v OFF");
  readVoltToSerial();
  tone(buzzerPin, 800, 100);
  if (Serial.available() > 0) {
    char input = Serial.read();
    if (input == '1') {
      Serial.println("1 -> B_C_Sel -> Bat connected/ not disconnect. Triggering B_C_Sel HIGH - LOW.");
      B_C_Sel_Status = !B_C_Sel_Status;
      tone(buzzerPin, 400, 100);
      digitalWrite(B_C_Sel, HIGH);
      delay(20);
      digitalWrite(B_C_Sel, LOW);
      readVoltToSerial();
    else if (input == '2') {   // EN_B_CH
      Serial.println("2 -> Activate/deactivate LiPo charging - Spiller 2 toner (400 Hz)");
      for (int i = 0; i < 2; i++) {
      // Bytt status og kjør HIGH-LOW puls
      EN_B_CH_Status = !EN_B_CH_Status;     // Veksler mellom true (1) og false (0)
      // Trigge HIGH-LOW puls for LiPo-lading
      digitalWrite(EN_B_CH, HIGH);
      delay(20);
      digitalWrite(EN_B_CH, LOW);
      // Vis status som 1 eller 0 i Serial
      Serial.print("LiPo-lading status: ");
      Serial.println(EN_B_CH_Status ? "1" : "0");
      // Les spenninger etter endring
      readVoltToSerial();
    else if (input == '3') {              // Slår av sensorer
      Serial.println("3 -> Switch on/off 3.3v sensors");
      digitalWrite(EN_SLP, EN_SLP_Status);
      Serial.println(EN_SLP_Status ? "Sensorer aktivert." : "Sensorer deaktivert.");
      Serial.println("Spiller 3 toner om 3.3 er på, ellers stille");
      for (int i = 0; i < 3; i++) {
      readVoltToSerial();
    else if (input == 'x') {
      Serial.println("x -> sleep - Spiller 4 toner (600 Hz)");
      for (int i = 0; i < 4; i++) {
      readVoltToSerial();
      digitalWrite(EN_SLP, LOW);   // Switch off 3.3 and 5v when sleep
      resultSleepTime = sov15sek;
      esp_sleep_enable_timer_wakeup(resultSleepTime);
      Serial.println("Sleep: " + String((unsigned long)(resultSleepTime / 1000000UL)) + " sec");
      Serial.println("--------------------------------------");
      esp_deep_sleep_start();
  // Hent nåværende tid for debounce tare og calibrate
  // 1 - Tare-knapp (B_C_Sel) Veksle mellom Bat/Cap
  if (digitalRead(switchTare) == HIGH) {
    if (currentMillis - lastDebounceTimeTare > debounceDelay) {
      lastDebounceTimeTare = currentMillis; // Oppdater debounce-tid
      Serial.println("1 - B_C_Sel - Tare pressed. (Veksle mellom Bat/Cap)");
      delay(20);
      readVoltToSerial();
  if (digitalRead(switchCalibrate) == HIGH) {
    if (currentMillis - lastDebounceTimeCalibrate > debounceDelay) {
      lastDebounceTimeCalibrate = currentMillis; // Oppdater debounce-tid
      Serial.println("2-> EN_B_CH Default LOW=LiPo no charge");
      delay(20);
      tone(buzzerPin, 400, 1000);
      readVoltToSerial();
  readVoltToSerial();
  int sCapADCRaw = analogRead(sCapPin);
  float sCapVoltageOut = (sCapADCRaw / (float)ADC_MAX) * ADC_REF;    // OK Konverter til spenning (0-3.3V)
  float sCapVoltageIn = sCapVoltageOut * sCapScaleFactor;          // OK Kompenser for spenningsdeleren
  // Fyller myPayload med data
  Payload myPayload;
  myPayload.PsCapADCRaw     = sCapADCRaw;
  myPayload.PsCapVoltageOut = sCapVoltageOut;
  myPayload.PsCapVoltageIn  = sCapVoltageIn;
  myPayload.PB_C_Sel_Status = B_C_Sel_Status;
  myPayload.PEN_B_CH_Status = EN_B_CH_Status;
  myPayload.PEN_SLP_Status  = EN_SLP_Status;
  Serial.print("sCapADCRaw:     "); Serial.println(myPayload.PsCapADCRaw);
  Serial.print("sCapVoltageOut: "); Serial.println(myPayload.PsCapVoltageOut);
  Serial.print("sCapVoltageIn:  "); Serial.println(myPayload.PsCapVoltageIn);
  Serial.print("B_C_Sel_Status: "); Serial.println(myPayload.PB_C_Sel_Status);
  Serial.print("EN_B_CH_Status: "); Serial.println(myPayload.PEN_B_CH_Status);
  Serial.print("EN_SLP_Status:  "); Serial.println(myPayload.PEN_SLP_Status);
  printASCIIPacket(reinterpret_cast<uint8_t*>(&myPayload), sizeof(Payload));
  startmS = millis(); // Starttidspunkt settes til nåværende tid i millisekunder
  // her sjekkes og sendes pakken
  if (LoRa.transmit(reinterpret_cast<uint8_t*>(&myPayload), sizeof(Payload), 10000, TXpower, 5000)) {
    endmS = millis();
    TXPacketCount++;
    packet_is_OK(myPayload);  // overfører myPayload til function
    packet_is_Error();
  delay(5000);
//               FUNCTIONS
void packet_is_OK(Payload functionPayload) {  // Sender pakken om den er OK
  //3.3 og 5V må være på for å sende pakke
  uint16_t localCRC;
  localCRC = LoRa.CRCCCITT(reinterpret_cast<uint8_t*>(&functionPayload), sizeof(Payload), 0xFFFF);
  Serial.print("    Bytes sent:        "); Serial.println(sizeof(Payload));
  Serial.print("    TransmitTime:      "); Serial.print((endmS - startmS)); Serial.println(" mS");
  Serial.print("    PacketsSent:       "); Serial.println(TXPacketCount);
  Serial.print("    CRC:               "); Serial.println(localCRC, HEX); Serial.println();
  /*  Serial.println("    Payload sent: ");
    Serial.print("    sCapADCRaw:        "); Serial.println(myPayload.PsCapADCRaw);
    Serial.print("    sCapVoltageOut:    "); Serial.println(myPayload.PsCapVoltageOut, 2); // To desimaler for nøyaktig spenning
    Serial.print("    sCapVoltageIn:     "); Serial.println(myPayload.PsCapVoltageIn, 2); // To desimaler for nøyaktig spenning
    Serial.print("    B_C_Sel_Status:    "); Serial.println(myPayload.PB_C_Sel_Status ? "True" : "False");
    Serial.print("    EN_B_CH_Status:    "); Serial.println(myPayload.PEN_B_CH_Status ? "True" : "False");
    Serial.print("    EN_SLP_Status:     "); Serial.println(myPayload.PEN_SLP_Status ? "True" : "False");
  Serial.println("Pakken ble sendt OK!");
  Serial.print("sCapADCRaw: "); Serial.println(functionPayload.PsCapADCRaw);
  Serial.print("sCapVoltageOut: "); Serial.println(functionPayload.PsCapVoltageOut);
  Serial.print("sCapVoltageIn: "); Serial.println(functionPayload.PsCapVoltageIn);
  Serial.print("B_C_Sel_Status: "); Serial.println(functionPayload.PB_C_Sel_Status);
  Serial.print("EN_B_CH_Status: "); Serial.println(functionPayload.PEN_B_CH_Status);
  Serial.print("EN_SLP_Status: "); Serial.println(functionPayload.PEN_SLP_Status);
void packet_is_Error() {
  uint16_t IRQStatus;
  IRQStatus = LoRa.readIrqStatus();
  Serial.print(F(" SendError: "));
  Serial.print(F(" Length: "));
  Serial.print(sizeof(Payload));
  Serial.print(F(" IRQreg: "));
  Serial.print(IRQStatus, HEX);
  LoRa.printIrqStatus();
void readVoltToSerial() {
  int solVerdi   = analogRead(solPin);
  int LiPoVerdi  = analogRead(LiPoPin);
  //  float solSpenning  = (solVerdi  / 4095.0) * referanseSpenning * solDividerFactor;
  //  float sCapSpenning = (sCapVerdi / 4095.0) * referanseSpenning * sCapDividerFactor;
  //  float LiPoSpenning = (LiPoVerdi / 4095.0) * referanseSpenning * LiPoDividerFactor;
  // float sCapVoltageIn = sCapVoltageOut * 60.6;                    // OK Kompenser for spenningsdeleren. For å beregne tilbake til inngangsspenningen
  Serial.print("sCap ADC Value raw:      ");  Serial.println(sCapADCRaw);
  Serial.print("sCap voltage Out (ADC):  ");  Serial.println(sCapVoltageOut, 3);
  Serial.print("sCap Voltage In (Real):  ");  Serial.println(sCapVoltageIn, 3);
  Serial.println("Status now: ");
  Serial.println("'1' Pulse B_C_Sel_Status (bat or cap) : 1 = Lipo power      0 = SuperCap: " + String(B_C_Sel_Status));
  Serial.println("'2' Pulse EN_B_CH_Status (LiPo charge): 1 = LiPo charge ON, 0 = Off:      " + String(EN_B_CH_Status));
  Serial.println("'3' EN_SLP_Status  (volt on / off)    : 1 = 3.3 og 5V ON    0 = Off:      " + String(EN_SLP_Status));
  /*  Serial.println("Volt meassure: ");
    Serial.println("Source;Volt;raw");
    Serial.print("sCap;"); Serial.print(sCapSpenning); Serial.print(";"); Serial.print(sCapVerdi); Serial.println(";");
    Serial.print("lipo;"); Serial.print(LiPoSpenning); Serial.print(";"); Serial.print(LiPoVerdi); Serial.println(";");
    Serial.print("sol ;"); Serial.print(solSpenning);  Serial.print(";"); Serial.print(solVerdi);  Serial.println(";");
  Serial.println("------------------------------------------------------------------------------------------------");
// Håndter knappetrykk generelt
void handleButtonPress(int buttonPin, bool & buttonState, unsigned long & lastDebounceTime, const unsigned long debounceDelay, const char* actionMessage, int triggerPin) {
  bool currentButtonState = digitalRead(buttonPin);
  if (currentButtonState == HIGH && !buttonState && (millis() - lastDebounceTime > debounceDelay)) {
    buttonState = true;
    lastDebounceTime = millis();
    Serial.println(actionMessage);
  if (currentButtonState == LOW && buttonState) {
    buttonState = false;
void PrintFileInfoAndVersion() {
  Serial.println("    Kompileringsinformasjon:");
  Serial.print  ("    Filnavn kode:     "); Serial.println(__FILE__);    // Makroer
  Serial.print  ("    Kompileringsdato: "); Serial.println(__DATE__);
  Serial.print  ("    Klokkeslett:      "); Serial.println(__TIME__);
  // Hent versjonsnummer direkte
  const char* dotPos = strrchr(__FILE__, '.');  // Finn posisjonen til siste punktum i filbanen
  int mottagerVersjon = 0;
  if (dotPos != nullptr && (dotPos - __FILE__) >= 2) { // Sjekk at det finnes minst 2 tegn før punktum
    char versionStr[3]; // To siffer + nullterminator
    versionStr[0] = *(dotPos - 2);
    versionStr[1] = *(dotPos - 1);
    versionStr[2] = '\0';
    mottagerVersjon = atoi(versionStr); // Konverter til heltall
  Serial.println("------------------------------------------------------");
void printASCIIPacket(const uint8_t* data, size_t length) {
  Serial.println("    Packet:            ");
  printHexBytes(data, length);               // skriver ut pakken i HEX
void printHexBytes(const uint8_t* data, size_t length) {
  for (size_t i = 0; i < length; i++) {
    if (data[i] < 0x10) {
      Serial.print(F("0"));
    Serial.print(data[i], HEX);
    Serial.print(F(" "));
settings.h
//*******  Setup hardware pin definitions here ! ***************
// LoRa
#define NSS     5                              // select pin on LoRa device
#define NRESET 14                              // reset pin on LoRa device
#define LED1   -1                              // on board LED, high for on
#define DIO0   16                              // DIO0 pin on LoRa device, used for RX and TX done
#define DIO1   -1                              // DIO1 pin on LoRa device, normally not used so set to -1
#define DIO2   -1                              // DIO2 pin on LoRa device, normally not used so set to -1
#define LORA_DEVICE DEVICE_SX1278              // we need to define the device we are using
//*******  Setup LoRa Parameters Here ! ***************
const uint32_t Frequency       = 868000000;    // frequency of transmissions in hertz
const uint32_t Offset          = 0;            // offset frequency for calibration purposes
const uint8_t Bandwidth        = LORA_BW_125;  // LoRa bandwidth
const uint8_t SpreadingFactor  = LORA_SF7;     // LoRa spreading factor
const uint8_t CodeRate         = LORA_CR_4_5;  // LoRa coding rate
const uint8_t Optimisation     = LDRO_AUTO;    // low data rate optimisation setting, normally set to auto
const int8_t TXpower           = 10;           // LoRa transmit power in dBm
const uint16_t packet_delay    = 10000;        // mS delay between packets
void setupLoRaSettings(SX127XLT &lt) {
  lt.setMode(MODE_STDBY_RC);
  lt.setPacketType(PACKET_TYPE_LORA);
  lt.setRfFrequency(Frequency, Offset);
  lt.calibrateImage(0);
  lt.setModulationParams(SpreadingFactor, Bandwidth, CodeRate, LDRO_AUTO);
  lt.setBufferBaseAddress(0x00, 0x00);
  lt.setPacketParams(8, LORA_PACKET_VARIABLE_LENGTH, 255, LORA_CRC_ON, LORA_IQ_NORMAL);
  lt.setSyncWord(LORA_MAC_PRIVATE_SYNCWORD);
  lt.setHighSensitivity();
  lt.setDioIrqParams(IRQ_RADIO_ALL, IRQ_TX_DONE, 0, 0);
  Serial.println(F("--------------------------------------"));
  Serial.println(F("ModemSettings:      ")); lt.printModemSettings(); Serial.println();
  Serial.println(F("OperatingSettings:  ")); lt.printOperatingSettings(); Serial.println();
  Serial.println("LoRa sender klar!     ");
Then when the sketch tries to configure the LoRa module it cannot find it due to wiring error, module error etc.
Try one of the basic send and receive examples in the library, much easier to see whats going on.
