LoRa Simple Communication with Nemeus XM001
Hi everyone,
I am currently working on a project in school. I have to create a LoRa communication between two arduino.
To do this I have the following elements :
  • 2 Arduino uno board
  • 2 NEMEUS RF module (PRODUCT ID: XM001-EU)
  • 2 Antenna
The problem is that I have no technical skills in LoRa nor in Radio Communication and no tutorials or similar project (using the Nemeus XM001) exists.
Based on the tutorial : Mobilefish.com - Build Lora node using Arduino Uno and HopeRF RFM95 LoRa transceiver module.
I realized this wiring:
![](https://forum.arduino.cc/Users/baptiste/Desktop/Capture d’écran 2019-01-14 à 11.36.23.png)
Using the "Lora.h" library, I do the equivalence with the Nemeus board :
![](https://forum.arduino.cc/Users/baptiste/Desktop/Corres table.png)
But when I run the "LoraSender" example code from the LoRa library,
I get the "Starting LoRa failed!" error message.
Can you please help me to find the errors ?
I am totaly unskilled so this project is hard for me.
Thank you.
Do post a schematic drawing of your actual circuit, and links to the specific libraries you run.
Another thing: don't mix up LoRa with LoRaWAN. Two different things.
And a direct linhk to the actual module you are using.
If the LoRa module is 3.3V, and most are, you did use logic level conversion between Arduino Uno and LoRa module ?
Finally, I don't use SPI communication but UART communication.
Here is the schematic (for the sender):
![](https://forum.arduino.cc/Users/baptiste/Desktop/Capture d’écran 2019-01-14 à 15.53.39.png)
I read that maybe I have to use the "WakeUp" Port.
The module is this one :
(I linked the wiring table)
The UART communication seems to be very Easy but I think I am missing an important point.
I think the module that I work on has a lot of features compared to the features that I need to use.
I've used RFM95 modules; very easy to get going over SPI using the RadioHead library.
Works fine with both a NodeMCU and a 3.3V Pro Mini. The latter works great on 2xAA batteries.
Cyclotron2:
I think you will find the Library you are using is for the SPI based LoRa module, not a UART one.
There is no data on your module at the page you linked to.
srnet:
Sorry, you will find data on this page :
Yes after some research, I found out that the "LoRa.h" library is for the SPI but I also found out that the UART communication is probably easier to build and code.
So I choose to do it as simple as it can be and to do it using UART communication.
But if you can help me with the SPI method, I also can do it this way.
Thanks a lot for your support !
Cyclotron2:
It might be easier to build and code, but only if you can find the data on how to drive it and\or a library.
So your choice is now a "more complicated" 4-wire instead of 2-wire connection, or going through the effort of writing your own library.
I'd go for the two extra wires.
Don't forget the level shifters.
wvmarle:
I am quite lost right now ...
So what would you do in my shoes ?
Cyclotron2:
The choice is clear;
Use a standard SPI based LoRa module, RFM96/8, DRF1276/8 etc, with a standard Arduino library and known working examples.
or
Find the data on your UART module and write your own library and examples, there probably is not one already.
Using a 3.3V Arduino, Pro Mini for instance, is a lot easier than using level shifters.
The problem is that I have to use this module.
I thought that this kind of module was "generic" and that some librairies can work also on all of them. Am I wrong?
The pin table you attached to #0 shows SPI connections. Pin 6, 7 and 9 (plus pin 10, GND, which of course you have connected alraedy). So what's keeping you from using that?
Actually I realise the extra wiring of SPI over UART is just one wire... You need three for UART (TX, RX, GND) vs. four for SPI (MISO, MOSI, CS, GND).
Cyclotron2:
Have you found a library or even the full data on the module ?
Okay,
Here is a little update of my wiring to get input in my module in 3.3V :
![](https://forum.arduino.cc/Users/baptiste/Desktop/New Wiring.png)
My code is this very simple one (in joined documents).
I used this code in Case of a direct communication between two arduino(RX/TX communication).
It doesn't seems to work with this wiring.(Or if it works the software of Radio visualization that I use doesn't work well, if you know another one?)
srnet:
I think that using UART communication (RX/TX), I don't need any library.
Concerning the Data about the module I can't find anything intersting. I called the supplier yesterday to get the data sheet, they will send it to me within today.
Thanks you for your comments guys ! Your help is really appreciated :slight_smile:
Code_emmeteur.ino (188 Bytes)
A library is never a strict necessity, but it can make life a lot easier.
If you can get it working with e.g. the RadioHead library you get all the goodies that come with it - such as encryption, addressed messages, automatic resends, etc.
