Hi Everyone.
Using Nanos and LoRa RA-01.
I am sending 3 packets of data to a LoRa receiver.
The one packet is the unit Id which is 102 , I can receive and print the 102 and test if 102 was received.
Then when the unit id is 102 I switch on a LED to indicate a valid id Received.
//------- Up to here all works fine ........
The problem stars here.
When the Rx id is confirmed I send 102 back to the Transmitter but the Transmitter never seem to goto to "while (LoRa.available())".
This is how I test what lines is executed.
Serial.println("1");
int packetSize = LoRa.parsePacket(); // try to parse packet
Serial.println("2");
if (packetSize)
Serial.println("3");
Serial.println("4");
incoming = ((int)LoRa.read());//char
Once in a BLUE MOON running for a long time the Led on the Tx unit will light up indicating that the id was received.
Both my pcb is exactly the same so I also swap the 2 Nanos (swap Rx and Tx sketch) and then only the Rx unit will switch on the Led.
Thanks for any help in advance.
//7 12 2021
//After TX data is send unit will wait for Rx data and then -
//If RX data (ack)match unit ID LED will switch on.
//No ack received LED will switch off.
#include <SPI.h>
#include <LoRa.h>
int incoming = 0;
int counterA = 0;
int counterB = 0;
long int unitId = 102;
int analog = 128;
int switch1 = 0;
int switch2 = 0;
long int data = 0;
int digital = 10;
pinMode(3, OUTPUT); //ack LED
while (!Serial);
Serial.println("LoRaTx Telem01");
if (!LoRa.begin(433E6))
Serial.println("Starting LoRa failed!");
while (1);
counterA = counterA + 1;//TX Interval Timer
counterB = counterB + 1;//no ack Timer
if (counterB == 20)
digitalWrite(3, LOW); //LED OFF
LoRa.begin(433E6);//Restart Lora
if (counterA == 5)//Send packet every 5 Seconds
// send packet
LoRa.beginPacket();
LoRa.write(unitId);//
LoRa.write(analog);//
LoRa.write(digital);//
// LoRa.print(analog);//
LoRa.endPacket();
counterA = 0;//clear counterA to start 5Sec timer
//---- Wait for acknow ---------------
if (packetSize)
Serial.print(incoming);
if (incoming == (unitId))
digitalWrite(3, HIGH);
incoming = 0;//clear value
counterB = 0;//Reset counterB 20 SEC Counter
//When received unit ID match , unit will respond and TX unit ID back ..Led on
//LED will switch off if no data is received in ~~20 Seconds
#include <SPI.h>
#include <LoRa.h>
#include <LiquidCrystal.h> //Arduino standard LCD Library
// RS E D4 D5 D6 D7
LiquidCrystal lcd(14, 15, 16, 17, 18, 19);
//const unsigned int numReadings = 10;
unsigned int myArray[3];
const unsigned long eventInterval = 1000;//used in millis
unsigned long previousTime = 0;//used in millis
int incoming ;
int rxData;
int i = 0;
int value = 0;
int analog = 0;
int unitId = 102;
int digital = 0;
int readFlag = 1;
int idFlag = 0;//0 = not valid
int counter = 0;
int rxId = 0;
//------ Configure I/O Pins -------
pinMode(3, OUTPUT); //Test LED
//------ Test LED ---------------
//------ Setup Serial & LCD -----
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("LoraRx Telem01");//This works
lcd.clear();
//-----Configure LoRa -----------
while (!Serial);
Serial.println("LoRaRxTelem01");
while (1);
//------ END of Setup -----------
unsigned long currentTime = millis();
if (currentTime - previousTime >= eventInterval)//eventInterval = 1000
counter = counter + 1;//increment counter every ~~ 1sec
previousTime = currentTime;
if (counter > 10)//Clear counter in LoRa.Read
i = 0;//start of Array
if (packetSize)
counter = 0;//Reset Counter valid read was done
readFlag = 0;
//----- Save Read packets in Array --------------
myArray[i] = incoming ;//save and loop until packet == size
i = i + 1; //Increment Array pointer until pacckets is Read
//------- Done reading packets ----------------------
if (readFlag == 0)//ReadFlag is "0" when new packet is Read.Prevent looping in Array Read
i = 0;
rxId = ( myArray[i]);//1
Serial.print ("rxid ");
Serial.print (rxId);
if (rxId == unitId)
digitalWrite(3, HIGH);//LED on when id is valid
idFlag = 1; //Set Flag id is valid, will reply id/2
i = i + 1;
analog = ( myArray[i]);//2
Serial.print ("analog ");
Serial.print (analog);
i = i + 1;
digital = ( myArray[i]);//3
Serial.print ("digital ");
Serial.print (digital);
readFlag = 1;//Array read done prevent looping until new packet is received
//---- id is valid answer back with id -------
if (idFlag == 1)
LoRa.beginPacket();
LoRa.write(unitId ); //
LoRa.endPacket();
idFlag = 0;//Reset idFlag for next read
//Serial.print(unitId);
