Lora using a variable as a Node number
On the attached sketch I am seeking a way to substitute (Line 35) "Lora.write(Node2) "for a variable "Lora.write(Variable).
eg If variable was a "23" then thats for for Node1.
If variable was a "76" then thats for for Node2. etc, etc
Is that possible ??
Thanks in advance
#include <SPI.h>
#include <LoRa.h>
byte Master = 0xAA;   //  int is 170
byte Node1 = 0xBB;    //  int is 187
byte Node2 = 0xCC;    //  int is 204
byte Node3 = 0xDD;    //  int is 221
byte Node4 = 0xEE;    //  int is 238
long int senT = 0;
long int reC = 0;
  Serial.println("Start LoRa duplex  TX  Sender");
  if (!LoRa.begin(915E6)) {
    Serial.println("LoRa init failed. Check your connections.");
    while (true) {}
void senddatA()
  String sendbacK = String(senT);
  sendMessage(sendbacK);
void sendMessage(String outgoing) {
  LoRa.beginPacket();
  LoRa.write(Node2);
  LoRa.write(Master);
  LoRa.write(outgoing.length());
  LoRa.print(outgoing);
  LoRa.endPacket();
void receiveMessage(int packetSize) {
  if (packetSize == 0) return;
  int recipient = LoRa.read();
  byte sender = LoRa.read();
  byte incomingLength = LoRa.read();
  String incoming = "";
  while (LoRa.available()) {
    incoming += (char)LoRa.read();
  if (incomingLength != incoming.length()) {
    //Serial.println("Error: Message length does not match length");
    return;
  if (recipient != Master) {
    //Serial.println("Error: Recipient address does not match local address");
    return;
  reC = incoming.toInt();
  senT = 120; senddatA();
  receiveMessage(LoRa.parsePacket());
Node2 is a variable
See byte - Arduino Reference
Unclear what question you are asking here.
Node2 is already a variable so easy to change with;
Node2 = 0x01;
etc.
If your wanting to be sure that the destination only responds to valid packets, maybe look at this;
I find it simpler to use a structure to transmit complex information from multiple nodes over LoRa etc
have a look at decimals-strings-and-lora
Thanks but what I am looking for is something that can be changed easilly depending on the what variable is rteceived from somewhere else in the sketch
  LoRa.beginPacket();
  LoRa.write(Node2);  ****** I am looking for some way to change this using another "variable".
EG  if I want to send an interger only to node 1 ,then I would use
 If  ("variable"= 1){ "then node = Node1"}
if ("variable"= 2){ "then node = Node2"}
if ("variable"= 3){ "then node = Node3"}
  LoRa.write(Master);
  LoRa.endPacket();
You can easily change Node2 to have some other value. Just like any other variable.
Thanks for your reply.
I realise that I can change the Node number manually but I wish to change it from outside " void sendMessage(String outgoing()" .
Perhaps you could give me an example of how this is done.
Thanks
byte DestinationNodeNumber;              //create global variable
LoRa.beginPacket();
LoRa.write(DestinationNodeNumber);
//etc
I apologise for not being able to express my problem adequately.
Heres a way I have come up with achieving my goal using "case" but
its the first time using "case" and I cannot get it work.
The " switch (var) " selects only the first "case" so that if the " switch (var) " is 1 it works just fine however if the " switch (var) " is 2 , 3 , or 4 it does not seem to switch to the appropriate "case 2,3 or4".
What am I missing ?
#include <SPI.h>
#include <LoRa.h>
long int senT = 0;
long int reC = 0;
int var = 0;
    while (true) {}
void SenDDatA() {
  Serial.print("   Inside SENDDATA()  (VAR) = "); Serial.println(var);
  switch (var)
    case 1:
      Serial.println("   Inside CASE 1 ");
      String outgoing1 = String(senT);
      LoRa.beginPacket();
      Serial.print("  Sent to Node 1  ");
      LoRa.write(Node1);
      LoRa.write(Master);
      LoRa.write(outgoing1.length());
      LoRa.print(outgoing1);
      Serial.println(outgoing1);
      LoRa.endPacket();
    case 2:
      Serial.println("   Inside CASE 2 ");
      String outgoing2 = String(senT);
      LoRa.beginPacket();
      LoRa.write(Node2);
      LoRa.write(Master);
      LoRa.write(outgoing2.length());
      LoRa.print(outgoing2);
      Serial.println(outgoing2);
      LoRa.endPacket();
    default:
      Serial.println("   No Case Number ");
  var = 2;
  senT = 65; SenDDatA();
Interestingly though, this code works, so it would appear as though
my error is in the "Lora.write " portion of the code.
      LoRa.beginPacket();
      LoRa.write(Node2);
      LoRa.write(Master);
      LoRa.endPacket();
Sorry I pasted the wrong code.
void SenDDatA() {
  switch (var)
    case 1:
    case 2:
    default:
