Bonjour j'ai ce sketch:
Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
Permission is hereby granted, free of charge, to anyone
obtaining a copy of this document and accompanying files,
to do whatever they want with them without any restriction,
including, but not limited to, copying, modification and redistribution.
NO WARRANTY OF ANY KIND IS PROVIDED.
This example sends a valid LoRaWAN packet with payload "Hello,
world!", using frequency and encryption settings matching those of
the (early prototype version of) The Things Network.
Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in g1,
0.1% in g2).
Change DEVADDR to a unique address!
See http://thethingsnetwork.org/wiki/AddressSpace
Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#define LMIC_DEBUG_LEVEL 2
// Change this!
// This should be in little endian format.
static const u1_t PROGMEM DEVEUI[8] = {0xca, 0xde, 0xe3, 0xaf, 0x1c, 0xde, 0xad, 0x0b};
void os_getDevEui (u1_t* buf) {
memcpy_P(buf, DEVEUI, 8);
// Change this!
static const u1_t PROGMEM APPKEY[16] = {0x22, 0x22, 0x22, 0x22, 0x22, 0x22, 0x22, 0x22, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
void os_getDevKey (u1_t* buf) {
memcpy_P(buf, APPKEY, 16);
static osjob_t sendjob;
// Schedule TX every this many seconds
const unsigned TX_INTERVAL = 40;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch (ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
case EV_JOINING:
Serial.println(F("EV_JOINING"));
case EV_JOINED:
Serial.println(F("EV_JOINED"));
case EV_RFU1:
Serial.println(F("EV_RFU1"));
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.dataLen) {
// data received in rx slot after tx
Serial.print(F("Data Received: "));
Serial.write(LMIC.frame + LMIC.dataBeg, LMIC.dataLen);
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
case EV_RESET:
Serial.println(F("EV_RESET"));
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
default:
Serial.println(F("Unknown event"));
byte buffer[52];
void do_send(osjob_t* j) {
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
// Prepare upstream data transmission at the next possible time.
String message = "IoT is cool";
message.getBytes(buffer, message.length() + 1);
Serial.println("Sending: " + message);
LMIC_setTxData2(1, (uint8_t*) buffer, message.length() , 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
// Leave this empty
static const u1_t PROGMEM APPEUI[8] = {};
void os_getArtEui (u1_t* buf) {
memcpy_P(buf, APPEUI, 8);
Serial.println(F("Starting"));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
// Disable link check validation
LMIC_setLinkCheckMode(0);
// LMIC_setDrTxpow(DR_SF7, 23);
// LMIC_setDrTxpow(DR_SF8, 23);
// LMIC_setDrTxpow(DR_SF9, 23);
// LMIC_setDrTxpow(DR_SF10, 23);
// LMIC_setDrTxpow(DR_SF11, 23);
// LMIC_setDrTxpow(DR_SF12, 23);
// Start job
do_send(&sendjob);
os_runloop_once();
et ce sketch:
const int trigPin = 9;
const int echoPin = 10;
float duration, distance;
void setup(){
pinMode(LED_BUILTIN, OUTPUT);
pinMode(8,OUTPUT);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
void loop(){
Serial.print("temps en secondes : ");
Serial.println(millis()/1000);
static bool isOccupied=false;
static unsigned long occupiedStartTime=0;
static unsigned long lastTransitionTime=0;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration * 0.0343) / 2;
Serial.print("Distance en cm : ");
Serial.println(distance);
if(!isOccupied && distance>6 && millis()==0){
Serial.println(isOccupied);
if(!isOccupied && distance <= 6){
if(millis()-lastTransitionTime>=20000){
isOccupied=true;
lastTransitionTime=millis();
//Serial.println(isOccupied);
}else if(!isOccupied && distance>6){
occupiedStartTime=millis();
}else if(isOccupied && distance>6){
isOccupied=false;
}else if (isOccupied && distance <= 6) { // Si l'objet était occupé et est maintenant à une distance <= 6
occupiedStartTime = millis(); // Réinitialiser le temps de début d'occupation
lastTransitionTime = millis(); // Réinitialiser le temps de la dernière transition
if(isOccupied){
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(8, LOW);
} else if (!isOccupied){
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(8, HIGH);
//Serial.println(millis());
J;aimerais que la variable isOccupied que je calcule dans le deuxeme sketch soit envoyes par paquets LORAWAN en demarrant le premier code.
mon probleme c'est que je n'arrive pas a envoyer isOccupied au premier sketch pour qu'il l'envoie par paquet et en essayant de fusionner les 2 codes en un seul, j'obtiens des resultats decevants.. comment faire ?
