I am currently writing a datalogger program and wanted it not to overwrite old files on the SD card. So I have it look for the file basename Apollo, start with 0 and check to see if /Apollo#.txt exists. If it does, increment to the next number and so on until it doesn't find the file name and that becomes the new file to write to. However, my designated filename , char* logFile, appears to get corrupted leaving me puzzled. I have even stripped the file of all sensor data, server info, etc. to the bare bones to trace. In the set-up, I do the search and set the filename. I confirm this with Serial output. I then have it show me that name again in the loop() function. It does it once (most of the time). The second time, it glitches. I am not sure where to go from here. It is probably something simple, but I am missing it.
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#include "FS.h"
#include "SD.h"
#include "SPI.h"
// Set these to your desired credentials.
const char *ssid = "Apollo1";
const char *password = "ghost12345"; // Must be at least 8 characters
String Measurement = "";
int logger;
int hh=0;
char* logFile;
WiFiServer server(80);
Serial.println("Configuring access point...");
// You can remove the password parameter if you want the AP to be open.
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
Serial.println("Server started: Apollo1");
Serial.println("");
Serial.println("SD Card check");
if(!SD.begin()){
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE){
Serial.println("No SD card attached");
return;
Serial.print("SD Card Type: ");
if(cardType == CARD_MMC){
Serial.println("MMC");
else if(cardType == CARD_SD){
Serial.println("SDSC");
else if(cardType == CARD_SDHC){
Serial.println("SDHC");
else {
Serial.println("UNKNOWN");
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluMB\n", cardSize);
char hhfilename[14];
sprintf(hhfilename,"/Apollo%d.txt",hh);
while(SD.exists(hhfilename)){
Serial.print("Found data file: ");
Serial.println(hhfilename);
hh++;
logFile = hhfilename;
Serial.print("Data file chosen: ");
Serial.println(logFile);
logger = 0;
Serial.printf("Writing path: %s\n\n",logFile);
delay(5000);
Serial Output:
18:16:14.144 -> SD Card Type: SDHC
18:16:14.144 -> SD Card Size: 7583MB
18:16:14.144 -> Data file chosen: /Apollo0.txt
Writing path: /A���?:
18:16:14.144 ->
18:16:19.117 -> Writing path: �?
18:16:19.117 ->
