Losing Global Variable value partially
I am reading values from SD card and populating a global arrays: arrLats and arrLongs. The values of the array would be referenced to find deviation of real-time GPS coordinates - added a readGPS() function.
I am facing a problem wherein I lose the global array values inside loop() function if I use readGPS() - I see only one of array value on serial output. If I simply comment out the call to readGPS(), I am able to see the output of arrLats and arrLongs.
Not sure what could be the reason for this. I would appreciate your help on this. FYR, the code & serial output:
CODE:-
(code with Code Tags!)
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
//********start - Global variables to read from SD card
File myFile;
float arrLats[4];
float arrLongs[4];
float fLat = 0;
float fLong = 0;
//********start - Global variables to read from GPS sheild
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  true
uint32_t timer = millis();
String NMEA1;  //We will use this variable to hold our first NMEA sentence
String NMEA2;  //We will use this variable to hold our second NMEA sentence
char c;       //Used to read the characters spewing from the GPS module
 String content = "";
 char character;
 String strLatLon = "";
 String strLat = "";
 String strLong = "";
 int idxComma = 0, idxNewline = 0, idxArray = 0;
 GPS.begin(9600);
 GPS.sendCommand("$PGCMD,33,0*6D");  //Turn off antenna update nuisance data
 GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA); //Request RMC and GGA Sentences only
 GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); //Set update rate to 1 hz
 pinMode(10, OUTPUT);
//--------Start read contents (reference lat/long) from SD file
 if(!SD.begin(10)){ Serial.println("initialization failed!");}
 else{
   myFile = SD.open("LatLon.txt");
   if (myFile)
     while(myFile.available())
       character = myFile.read();
       if (character != '\n' && character !='\r') {
         content.concat(character);
       else {
         Serial.println(content);
            strLatLon = content;
            idxComma =  strLatLon.indexOf(",");
            idxNewline = strLatLon.length();
            strLat = strLatLon.substring(0, idxComma);
            strLong = strLatLon.substring(idxComma + 1, idxNewline);
            strLat.trim();
            strLong.trim();
            arrLats[idxArray] = strLat.toFloat();
            arrLongs[idxArray] = strLong.toFloat();
            idxArray++;
            content = "";
            strLatLon = "";
            strLat = "";
            strLong = "";
            idxComma = 0;
            idxNewline = 0;
     myFile.close();
     Serial.println("error opening LatLon.txt");
//--------End read contents (reference lat/long) from SD file
 bool bReadGps;
 for (int i=0; i<4; i++) {
       Serial.println(i);
       Serial.println(arrLats[i]);
       Serial.println(arrLongs[i]);
   bReadGps = readGPS();
Code for readGPS() function:
boolean readGPS() {  //This function will read and remember two NMEA sentences from GPS
 clearGPS();    //Serial port probably has old or corrupt data, so begin by clearing it all out
 boolean bReturn = false;
 if (GPS.newNMEAreceived()) {
   if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
     return bReturn;  // we can fail to parse a sentence in which case we should just wait for another
 // if millis() or timer wraps around, we'll just reset it
 if (timer > millis())  timer = millis();
 // approximately every 2 seconds or so, print out the current stats
 if (millis() - timer > 2000) {
   timer = millis(); // reset the timer
   Serial.print("Fix: "); Serial.print((int)GPS.fix);
   Serial.print(" quality: "); Serial.println((int)GPS.fixquality);
   if (GPS.fix) {
     Serial.print("Location (in degrees, works with Google Maps): ");
     fLat = GPS.latitudeDegrees;
     Serial.print(fLat, 6);
     Serial.print(", ");
     fLong = GPS.longitudeDegrees;
     Serial.println(fLong, 6);
     bReturn = true;
 return bReturn;
void clearGPS() {  //Since between GPS reads, we still have data streaming in, we need to clear the old data by reading a few sentences, and discarding these
 while(!GPS.newNMEAreceived()) {
   c=GPS.read();
 GPS.parse(GPS.lastNMEA());
OUTPUT:-
If I comment readGPS() inside loop:
0
77.64
12.97
1
77.64
12.97
2
77.64
12.96
3
77.64
12.97
If I uncomment readGPS() inside loop:
0
77.64
0.00
1
77.64
0.00
2
77.64
0.00
3
77.64
0.00
I wonder if you aren't running out of SRAM. The SD library chews up a ton of it and I'm sure the GPS stuff does too. Try using F() on all the Serial prints of constant strings and see if that might help.
Do you know how much RAM you are using? You may have filled the RAM with those long strings:
I wouldn't expect this to fill the RAM but the library may have a lot of this sort of stuff inside it. Get into the habit of using the F() macro to store long strings in the flash memory:
Serial.println(F("error opening LatLon.txt"));
