Losing IP Addresses in UDP sketch...
I’m getting a headache. I’ve called the MIA department (Missing IP Address), but no love.
My test sketch is modelled after the UDPSendReceiveString example. I want to add simple UDP comms to an existing program so that it can communicate to other instances of the same program.
I have attached the code. I’ve defined two variables globally, set them as IPAddress() type. [Note: they were byte arrays at one point in time]
They appear to bet set correctly in setup(). But they are empty in loop(). At least by the time the Udp.beginPacket() is called.
Why???
Here is some test output:
10, 1, 1, 10 <-local
10, 1, 1, 20 <-remote
Setup: Found Ethernet Shield
Setup: Cable connected
Setup: UDP port connection successful to 8888
Loop: _UDP packet begin failed. Host not found
0, 0, 0, 0 <-local
0, 0, 0, 0 <-remote
1 characters sent
Error occurred during write
And here is the code…
// sends a message first
#include <SPI.h>
#include <Ethernet.h>
// #include <EthernetUdp2.h>
#define localID 10 // local
#define remoteID 20 // remote
#define localPORT 8888 // Port
#define EthMegPin 53
#define debugDelay 2500
#define Halt while(true)
#define Forever while(true)
boolean start = true;
// define UDP object
EthernetUDP sendUdp;
char UDPRecvBuffer[UDP_TX_PACKET_MAX_SIZE];
char UDPSendBuffer[] = "ack";
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xFE, 0x00 };
IPAddress local_IP;
IPAddress remote_IP;
int packetSize;
byte localScriptToken;
int remote_message = 0;
  pinMode(EthMegPin, OUTPUT);
  digitalWrite(EthMegPin, HIGH);
  // Ethernet.init(10);  // Most Arduino shields
  // localID read in setup
  mac[4] = localID;
  IPAddress local_IP( 10, 1, 1, localID );
  for (int i = 0; i < 4; i++) {
    Serial.print(local_IP[i]);
    if (i < 3) Serial.print(", ");
  }; Serial.println(" <-local");
  IPAddress remote_IP(10, 1, 1, remoteID);
    Serial.print(remote_IP[i]);
  }; Serial.println(" <-remote");
  Ethernet.begin(mac, local_IP);
  //print out the IP address
  Serial.print("Setup: Local IP = ");
  Serial.println(Ethernet.localIP());
  Serial.print("Setup: Rem't IP = 10, 1, 1, ");
  Serial.println(remoteID);
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Setup: Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    Halt;
    Serial.println("Setup: Found Ethernet Shield");
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Setup: Ethernet cable is not connected.");
    Halt;
    Serial.println("Setup: Cable connected");
  Serial.println("...");
  int Udp_Conn = sendUdp.begin(localPORT);
  if (Udp_Conn) {
    Serial.print("Setup: UDP port connection successful to ");
    Serial.println(localPORT);
  else {
    Serial.print("Setup: UDP port connection failed to ");
    Halt;
  // int UdpConn = sendUdp.beginPacket(remote_IP, sendUdp.remotePort());
  int UdpConn = sendUdp.beginPacket(remote_IP, 8888);
  if (UdpConn) {
    Serial.println("Loop: Begin packet successful");
  else {
    Serial.println("Loop: _UDP packet begin failed. Host not found");
    Serial.print("...Host device IP address: ");
  remote_message ++;
  itoa(remote_message, UDPSendBuffer, 10);
  int charsSent = sendUdp.write(UDPSendBuffer);
  delay(debugDelay);
  Serial.print(charsSent);
  Serial.println(" characters sent");
  int UdpSent = sendUdp.endPacket();
  if (UdpSent) {
    Serial.println("Message sent via UDP");
  else {
    Serial.println("Error occurred during write");
  //  delay(3000);
  Halt;
TII-Interact_commsTest_Send.ino (3.14 KB)
You declare them as globals. Then you redeclare them as local in setup and initialize them. The globals are untouched, as you see in loop.
A MAC address has 6 octets.
 mac[4] = localID;
This is a new variable, with the same name as the uninitialized global variable.
Same here.
This code, in loop(),
is printing the global variable that has never been initialized.
As far as the MAC address, I miscounted. Oops.
I think I finally get it. Since the Ip addresses get set in setup() and used in loop(), the two definitions are in conflict. The code before this one defined each address as a global 5 element byte array. Then IPAddress was used as a function, not a type, to initialize their values.
That’s wrong.
You all have given me the mental kick I needed. Thanks.
