Hello,
I'm currently working on a project using an Arduino Duemilanove and the Seeed Studio W5200 ethernet shield to connect to an MQTT server I'm running on a windows PC on my local network. I'm using knolleary's PubSubClient library and the EthernetV2_0 library for all of the network code. It's probably worth mentioning I'm also using a NRF24L01 transceiver radio, and because of issues trying to use multiple SPI devices with the Ethernet shield, I was forced to use software SPI in order to attempt to use both devices. For that I used the SoftSPI functionality of TMRH20's RF24 library. This is where my issues started, I can run the example code for a MQTT client perfectly fine, but as soon as I added the radio libraries (even if I don't initialize it or call any functions), I started having issues connecting to the MQTT server outside of the setup loop. Initializing the Ethernet connection using dhcp works fine, and the first connection and publishing to the MQTT server also works, but as soon as the program enters the loop code, I get a socket read error on the MQTT server (on the log from my computer running the sever) and the arduino client disconnects, and fails to reconnect indefinitely. The error code I'm getting from the PubSubLibrary is -2, which from what I understand indicates an error while attempting to establish a connection to the broker, which I believe means theres an issue with implementing the Ethernet library somewhere. The main problem is that I don't know why it works during setup, but then breaks as soon as the main loop is initialized. If anyone has any advice on what to test, or try to change, I've included the test code I've been working with to try to find the issue.
#include <SPI.h>
#include <EthernetV2_0.h>
#include <PubSubClient.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#include <DigitalIO.h>
#include "printf.h"
#define SDCARD_CS 4
byte mac[] = {0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED};
IPAddress ip(192, 168, 0, 37);
IPAddress server(192, 168, 0, 34);
EthernetClient ethClient;
PubSubClient client(ethClient);
RF24 radio(5,6);
const uint64_t pipes[2] = {0xF0F0F0F0AA, 0xF0F0F0F0BB};
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
if (client.connect("arduinoClient")) {
Serial.println("connected");
client.publish("openhab/Gateway","Receive Gateway reporting in");
client.subscribe("openhab/Command");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
delay(5000);
pinMode(SDCARD_CS,OUTPUT);
digitalWrite(SDCARD_CS, HIGH);
radio.begin();
radio.setRetries(15,15);
radio.enableDynamicPayloads();
radio.openReadingPipe(1,pipes[0]);
radio.printDetails();
radio.startListening();
client.setServer("192.168.0.34", 1883);
client.setCallback(callback);
Ethernet.begin(mac);
delay(1500);
Serial.println(Ethernet.localIP());
reconnect();
Serial.println(client.state());
if (!client.connected()) {
reconnect();
client.loop();
if(millis() - sensorTime > 5000){
boolean ok = client.publish("openhab/test", "test");
Serial.println(ok);
sensorTime = millis();
if(radio.available()){
int buf;
radio.read(&buf, radio.getPayloadSize());
Serial.println(buf);
