Losing my rag now..
Hi all
I am using windows 7 with Arduino software version 1.0.5.
Is it me just being a newbee or is it a bug in the software?, sometimes when I type within a void loop, matters not how I type the syntax it will not be recognised by the ide.
And I have even copied and pasted from the tutorial site mand it has worked even though my txt has been identical to the copy and pasted txt.
EG
if(LDRValue < Light_sensitivity)
I get a" Light_dependant_resistor:18: error: expected unqualified-id before if"
Please tell me what I am doing wrong when I type my txt.
Thanks
Don
You need to post your code.
Between code tags, please.
Sorry.
int LDR = 0;
int LDRValue = 0;
int light_sensitivity = 500;
    pinMode(13, OUTPUT);
  LDRValue = analogRead(LDR);
  Serial.println(LDRValue);
  delay(50);
    digitalWrite(13, HIGH);
    digitalWrite(13,LOW);
Is that better??
Get rid of the closing brace before the if statement.
Pete
C is case-sensitive; "light_sensitivity" is not the same as "Light_sensitivity"
You mean it gives exactly the same error or it still doesn't compile?
Show the error message.
Pete
Thanks AWOL. :blush:
Thanks to you too Pete for your advice and help.
I will try and ensure I post in the right place next time. No harm meant.
The compiler is the most nit-picking, infuriatingly pedantic device known.
You just have to out-pedant it.
You can set your cursor to the right of any brace [{()}].
IDE will then put a small blue box around the brace it belongs to.
If they do not belong together, you probably are missing one or have misplaced one.
