In reply to blh64, the following is the entire sketch:
loat AMPS1 = 0; //Current calculated from measured value.
float AMPS2 = 0;
float AMPS3 = 0;
float AMPS4 = 0;
float AMPS5 = 0;
float AMPS6 = 0;
float AMPS7 = 0;
float AMPS8 = 0;
float AMPS9 = 0;
float AMPS10 = 0;
float AMPS11 = 0;
float AMPS12 = 0;
float AMPS13 = 0;
float AMPS14 = 0;
float AMPS15 = 0;
float AMPS16 = 0;
int AMPR1 = 0; //Current rounded to nearest whole number.
int AMPR2 = 0;
int AMPR3 = 0;
int AMPR4 = 0;
int AMPR5 = 0;
int AMPR6 = 0;
int AMPR7 = 0;
int AMPR8 = 0;
int AMPR9 = 0;
int AMPR10 = 0;
int AMPR11 = 0;
int AMPR12 = 0;
int AMPR13 = 0;
int AMPR14 = 0;
int AMPR15 = 0;
int AMPR16 = 0;
const int A = 50; //Current sensor range value. (0-50 amps)
const int AMIN = 1023/A;
int PS;
int PC;
//Program//
//The reference anode must be defined for each system as the anode current value which is used to determine the point of peak current and the period of data acquisition.
//The reference anode in this program is Anode 4.
int AREF = 0; //Defines the anode current measurement that will be used as the refeence current. Anode current must be greater than to continue data acquisition.
int En = 0; //Calls for data acquisition.
int AnodeI = 0; //Pre-acquistion data to initialize data acquisition above reference anode current of 1 amp.
int PS = 0; //Value to ensure 1 print per rectifier cycle.
pinMode (A0, INPUT);
pinMode (A1, INPUT);
pinMode (A2, INPUT);
pinMode (A3, INPUT);
pinMode (A4, INPUT);
pinMode (A5, INPUT);
pinMode (A6, INPUT);
pinMode (A7, INPUT);
pinMode (A8, INPUT);
pinMode (A9, INPUT);
pinMode (A10, INPUT);
pinMode (A11, INPUT);
pinMode (A12, INPUT);
pinMode (A13, INPUT);
pinMode (A14, INPUT);
pinMode (A15, INPUT);
//BEGINNING OF LOOP//
Serial.print("Again PS=");
Serial.println(PS);
int StpPt; //Causes print to monitor only once per cycle.
int AREF;
int En;
int AnodeI;
int PS;
int Anode1; //Anode(x) contains the value for the anode current.
int Anode2;
int Anode3;
int Anode4; //Provides an initial reference anode current value equal to the equivalent of ~1 amp, which will permit data acquisition (> AREF).
int Anode5;
int Anode6;
int Anode7;
int Anode8;
int Anode9;
int Anode10;
int Anode11;
int Anode12;
int Anode13;
int Anode14;
int Anode15;
int Anode16;
if (En == 0)
int AnodeI = analogRead (A3); //AnodeI is only used to initialize the reading of anode currents. Once the reference anode current exceeds 1 amp, AnodeI is no longer used for the remainder of the cycle.
AREF = 25;
//If reference anode current value is above ~1 amp, initialize anolog read of all anodes by setting Enable=1.//
if (AnodeI > AMIN)
En = 1;
PS = 0; //Place "PS" reset here.
En = 0;
delay(5000);
//Data acquistion occurs if Enable is high and the reference anode current (in this case anode 4) continues to rise.//
if (AREF < Anode4 && En == 1){
//AREF = Anode4
delay(750); //0.75 second delay between analog reads.
int Anode1 = analogRead (A0); //Anode(x) contains the 0-1023 value for the anode current.
int Anode2 = analogRead (A1);
int Anode3 = analogRead (A2);
int Anode4 = analogRead (A3);
int Anode5 = analogRead (A4);
int Anode6 = analogRead (A5);
int Anode7 = analogRead (A6);
int Anode8 = analogRead (A7);
int Anode9 = analogRead (A8);
int Anode10 = analogRead (A9);
int Anode11 = analogRead (A10);
int Anode12 = analogRead (A11);
int Anode13 = analogRead (A12);
int Anode14 = analogRead (A13);
int Anode15 = analogRead (A14);
int Anode16 = analogRead (A15);
Serial.print("AREF=");
Serial.println(AREF);
Serial.print("Anode4=");
Serial.println(Anode4);
Serial.print("AMIN=");
Serial.println(AMIN);
if (AREF>AMIN && PS==0 && En==LOW){
float AMPS1 = Anode1 * (A/1023); //Changes measured value (0-1023) to current (0-50 amps).
float AMPS2 = Anode2 * (A/1023);
float AMPS3 = Anode3 * (A/1023);
float AMPS4 = Anode4 * (A/1023);
float AMPS5 = Anode5 * (A/1023);
float AMPS6 = Anode6 * (A/1023);
float AMPS7 = Anode7 * (A/1023);
float AMPS8 = Anode8 * (A/1023);
float AMPS9 = Anode9 * (A/1023);
float AMPS10 = Anode10 * (A/1023);
float AMPS11 = Anode11 * (A/1023);
float AMPS12 = Anode12 * (A/1023);
float AMPS13 = Anode13 * (A/1023);
float AMPS14 = Anode14 * (A/1023);
float AMPS15 = Anode15 * (A/1023);
float AMPS16 = Anode16 * (A/1023);
int AMPR1 = AMPS1 + .5; //Rounds current to nearest whole number and converts current value to an interger.
int AMPR2 = AMPS2 + .5;
int AMPR3 = AMPS3 + .5;
int AMPR4 = AMPS4 + .5;
int AMPR5 = AMPS5 + .5;
int AMPR6 = AMPS6 + .5;
int AMPR7 = AMPS7 + .5;
int AMPR8 = AMPS8 + .5;
int AMPR9 = AMPS9 + .5;
int AMPR10 = AMPS10 + .5;
int AMPR11 = AMPS11 + .5;
int AMPR12 = AMPS12 + .5;
int AMPR13 = AMPS13 + .5;
int AMPR14 = AMPS14 + .5;
int AMPR15 = AMPS15 + .5;
int AMPR16 = AMPS16 + .5;
Serial.print("Anode 1 = ");
Serial.print(AMPR1);
Serial.print(" ");
Serial.print("Anode 2 = ");
Serial.print(AMPR2);
Serial.print(" ");
Serial.print("Anode 3 = ");
Serial.print(AMPR3);
Serial.print(" ");
Serial.print("Anode 4 = ");
Serial.println(AMPR4);
Serial.print("Anode 5 = ");
Serial.print(AMPR5);
Serial.print(" ");
Serial.print("Anode 6 = ");
Serial.print(AMPR6);
Serial.print(" ");
Serial.print("Anode 7 = ");
Serial.print(AMPR7);
Serial.print(" ");
Serial.print("Anode 8 = ");
Serial.println(AMPR8);
Serial.print("Anode 9 = ");
Serial.print(AMPR9);
Serial.print(" ");
Serial.print("Anode 10 = ");
Serial.print(AMPR10);
Serial.print(" ");
Serial.print("Anode 11 = ");
Serial.print(AMPR11);
Serial.print(" ");
Serial.print("Anode 12 = ");
Serial.println(AMPR12);
Serial.print("Anode 13 = ");
Serial.print(AMPR13);
Serial.print(" ");
Serial.print("Anode 14 = ");
Serial.print(AMPR14);
Serial.print(" ");
Serial.print("Anode 15 = ");
Serial.print(AMPR15);
Serial.print(" ");
Serial.print("Anode 16 = ");
Serial.print(AMPR16);
PS++;
Serial.println("En=");
Serial.println(En);
//Once cycle has ended, reset all variables and values, except for reference anode value, which is set to AMIN.//
if(En == LOW)
int Anode1 = 0;
int Anode2 = 0;
int Anode3 = 0;
int Anode4 = AMIN; // **AMIN Anode(x) compared to AREF for data acquisition. Anode(x) current initialized to a value representing 1 amp for first pass.
int Anode5 = 0;
int Anode6 = 0;
int Anode7 = 0;
int Anode8 = 0;
int Anode9 = 0;
int Anode10 = 0;
int Anode11 = 0;
int Anode12 = 0;
int Anode13 = 0;
int Anode15 = 0;
int Anode16 = 0;
int AMPR2 = 0;
int AMPR3 = 0;
int AMPR4 = 0; //**int AMPR4 = 0
int AMPR5 = 0;
int AMPR6 = 0;
int AMPR7 = 0;
int AMPR8 = 0;
int AMPR9 = 0;
int AMPR10 = 0;
int AMPR11 = 0;
int AMPR12 = 0;
int AMPR13 = 0;
int AMPR14 = 0;
int AMPR15 = 0;
int AMPR16 = 0;
int AnodeI = 0;
int En = 0;
Serial.print("PS=");
Serial.println(PS);
In reply to Danois90, I will look at your link.
