Linux: Ubuntu 18.04 LTS
Arduino IDE 1.8.19
Yesterday everything worked great regarding the Arduino IDE. I was uploading to the WiFi Rev2, using serial monitor, seeing the UNO data on a webpage, etc.
Today I had to restart the computer and now I have no ACM0 port on the IDE port choices; only ttyS0 is an option. Although I can still see the UNO on the webpage link displaying data so the board is functioning in that regard.
I ran in terminal mode:
sudo ~/.arduino15/packages/arduino/hardware/megaavr/1.8.7/scripts/create_dfu_udev_rule
and
sudo usermod -a -G dialout <username>
Using the command:
sudo systemctl stop ModemManager
I stopped Modemmanager in case it was grabbing the port needed for the IDE.
I went further and disabled modemmanager:
ed@ed-G41MT-S2PT:~$ sudo systemctl stop ModemManager
[sudo] password for ed:
ed@ed-G41MT-S2PT:~$ sudo systemctl disable ModemManager
Removed /etc/systemd/system/multi-user.target.wants/ModemManager.service.
Removed /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service.
ed@ed-G41MT-S2PT:~$
If I plug in a USB cable used with an ESP32 it immediately recognizes the port as ttyUSB0.
Silicon Labs CP210x UART Bridge appears for the ESP32 USB cable when hooked up.
Additional terminal info:
ed@ed-G41MT-S2PT:~$ lsusb
Bus 001 Device 019: ID 046d:c315 Logitech, Inc. Classic Keyboard 200
Bus 001 Device 018: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 017: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 007: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
ed@ed-G41MT-S2PT:~$ cat .arduino/preferences.txt |grep serial
serial.databits=8
serial.debug_rate=9600
serial.parity=N
serial.port=COM1
serial.stopbits=1
serial.databits=8
serial.parity=N
serial.port=COM1
serial.stopbits=1
ed@ed-G41MT-S2PT:~$ ls -l /dev/ttyACM0
ls: cannot access '/dev/ttyACM0': No such file or directory
ed@ed-G41MT-S2PT:~$
