Lost on DS3218mg Servo
I recently purchased a few DS3218mg servo motors, I have used smaller servos in the past. I am trying to power it with a lith-ion battery. datasheet shows 4.8V to 7.2V In with a stall current of 1.8A at 6.8V, The battery is rated 7.4V 2200mAh. I can't seem to get the motor to do much of anything. Trying to figure out what I'm missing.
Thanks
What current can the battery supply though (mAh being its capacity, not current)?
Could the battery's 7.4V have damaged the servo which expects only 7.2A?
You obviously need some wiring and some code to get the servo to do anything. If we are going to help with your problems we need to see those things.
But since a fully charged 2S(7.4V nominal) Li-ion battery is 8.4V I think you are pushing your luck a bit running that servo on such a high voltage. I'd try it on 6V if possible (4 x alkaline AA cells would probably do for a quick test).
Steve
Sorry for the lack of information, here is what I am doing.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
I am now currently using 4-AA batteries connecting:
6V to red wire on DS3218
Ground to black wire on DS3218
Pin 9 from UNO R3 to white wire on DS3218
Servo is not moving at all
jbarth200:
And what about the battery ground / servo black to the Arduino ground?
That was it...duh!
Thanks a lot!
