Lots of Getting Started Links
See below or lots of good getting started stuff.
Moderator edit: Spam removed.
Hi, welcome to the group.
Here is your homework :).
Arduino links of interest.
How to use this forum:
https://forum.arduino.cc/index.php?topic=149014.0
Listing of downloadable 'Arduino PDFs' :
Either Google >>>- - - - > arduino filetype: pdf
Or
https://www.google.ca/search?q=arduino+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=arduino+filetype%3A+pdf&aqs=chrome..69i57j69i65.1385j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Listing of downloadable 'C++ PDFs' :
Either Google >>>- - - - > C++ filetype: pdf
Or
https://www.google.ca/search?q=c%2B%2B+filetype%3A+pdf&rlz=1C9BKJA_enCA739CA739&oq=c%2B%2B+filetype%3A+pdf&aqs=chrome..69i57.22790j0j7&hl=en-US&sourceid=chrome-mobile&ie=UTF-8
Arduino cheat sheet:
Watch these:
Arduino programming syntax:
Arduino arithmetic operators:
Arduino control flow:
Arduino data types:
Jeremy Blume:
Sparkfun External Interrupts
Sparkfun Timer1 Interrupts
Powering Your Projects
Understanding Destructive LC Voltage Spikes:
OR
Why MOSFET gate resistors:
Some things to read
LCD information:
Reading a schematic:
https://learn.sparkfun.com/tutorials/how-to-read-a-schematic
Language Reference:
https://www.arduino.cc/en/Reference/HomePage
Foundations:
How and Why to avoid delay():
http://playground.arduino.cc/Code/AvoidDelay
Demonstration code for several things at the same time.
http://forum.arduino.cc/index.php?topic=223286.0
Multitasking:
Part 1:
Part 2:
Part 3:
Neopixels, Adafruit
Fastled
Sparkfun Tutorials:
https://learn.sparkfun.com/tutorials?page=all
Micro Controllers:
Useful links:
Arduino programming traps, tips and style guide:
http://www.gammon.com.au/forum/?id=12153
Call for useful programming discussions
Arduino products:
https://www.arduino.cc/en/Main/Products
Motors/MOSFETs
http://www.gammon.com.au/motors
Switches:
http://www.gammon.com.au/forum/?id=11955
A good book you might want to get:
Share tips you have come across, 500+ posts:
Debug discussion:
Frequently Asked Questions:
https://www.arduino.cc/en/main/FAQ#toc10
Number 'type's:
  • boolean (8 bit) - simple logical true/false, Arduino does not use single bits for bool
  • byte (8 bit) - unsigned number from 0-255
  • char (8 bit) - signed number from -128 to 127. The compiler will attempt to interpret this data type as a character in some circumstances, which may yield unexpected results
  • unsigned char (8 bit) - same as 'byte'; if this is what you're after, you should use 'byte' instead, for reasons of clarity
  • word (16 bit) - unsigned number from 0-65535
  • unsigned int (16 bit)- the same as 'word'. Use 'word' instead for clarity and brevity
  • int (16 bit) - signed number from -32768 to 32767. This is most commonly what you see used for general purpose variables in Arduino example code provided with the IDE
  • unsigned long (32 bit) - unsigned number from 0-4,294,967,295. The most common usage of this is to store the result of the millis() function, which returns the number of milliseconds the current code has been running
  • long (32 bit) - signed number from -2,147,483,648 to 2,147,483,647
  • float (32 bit) - signed number from -3.4028235E38 to 3.4028235E38. Floating point on the Arduino is not native; the compiler has to jump through hoops to make it work. If you can avoid it, you should.
You should always select the 'data type' best suited for your variables.
ex:
  • your variable does not change and it defines a pin on the Arduino. const byte limitSwitchPin = 34;
  • since an analog variable can be 0 to 1023, a byte will not do, you can select 'int'. ex: int temperature;
  • if your variable needs to be within -64 to +64 a 'char' will do nicely. ex: char joystick;
  • if your variable is used for ASCII then you need type 'char', ex: char myText = {"Raspberry Pie Smells"};
  • if your variable enables some code then boolean can be used. ex: boolean enableFlag = false;
  • millis() returns the time in ms since rebooting, ex: unsigned long currentTime = millis();
    etc.
Oh, and have fun too :slight_smile: !
Hello i am new as well in this forum
You have to do the same home work too. :wink:
larryd:
I hope you read all that stuff yourself :slight_smile:
...R
Robin2:
...R
Yes, 3 times.
However, only remember the last time and quickly loosing that too. :wink:
This is burned into the neutrons. :slight_smile:
i am also new!
i just started learning today, because in my school we're doing a contest and the winner gets a arduino robot thingy!
(i am 10, mind your own business!)
lankycode:
We don't mind what age you are (I'm 68) but the "mind your own business" is just rude and unfriendly.
Assuming you plan to be a friendly member of the Forum, then, Welcome, have fun.
...R
Robin2:
...R
it was a joke....
lankycode:
it was a joke…
Fair enough. But you should realise that things which are amusing when spoken to a person who can see you, and see the expression on your face, may not appear funny to a stranger who is reading the same words.
…R
