Loud vibrating nema 17 stepper while turning with hall effect homing function
Hi!
I'm trying to let the stepper motors (nema17) perform a homing function and turn to a specific angle.
Obviously there's way too much sound and vibration (see video) and the motors feel like they are strugling
Here is the link to the video: Loud vibrating nema 17 stepper while turning with hall effect homing function - YouTube
Thank you in advance :slight_smile:
// Define connections
#define HALL_SENSOR 10
#define DIR 2
#define STEP 3
// Direction Variable
boolean setdir = LOW;
void homefunction() {
  //Set motor speed pulse duration
  int pd = 4000;
  //Move motor until home position reached
  while (digitalRead (HALL_SENSOR) ==1) {
    digitalWrite(DIR, setdir);
    digitalWrite(STEP, HIGH);
    delayMicroseconds(pd);
    digitalWrite(STEP, LOW);
    delayMicroseconds(pd);}
  //setup the stepper controller pins as Outputs
    pinMode(DIR, OUTPUT);
    pinMode(STEP, OUTPUT);
  //setup the hall effect switche  as an Input
    pinMode(HALL_SENSOR, INPUT);
  // home the motor
  homefunction();
void loop(){
 //step(true,600);
// delay(50);
// step(false,600);
// delay(50000);
Sounds perfectly normal! The mounting of the stepper motors will quiet that down, if designed properly.
Paul
and is there a way to make them rotate slower so I would have a more precise homing function?
a bit like a homing function of a 3D printer :smiley:
Can you please post a circuit diagram?
A hand drawn picture will be fine.
What drivers are you using?
Can you post a link to thier specs/data?
Google this;
arduino accelstepper tutorial
It explains using accelstepper libary that may help.
Tom... :smiley: :+1: :coffee: :australia:
Simple, just don’t send the pulses so fast.
I have just spent a week or so playing with some steppers. A comment I would make is that generally they run smoothly when they are run properly. but are noisier at low speed than at higher speed.
For a while I had the connections from the driver to the motor incorrectly wired and it would not run at all at high speeds or run with energetic thumping noises very slow speeds (< 5 steps/sec) and the motor really felt like it was not happy.
Also if you run half step mode it will be quieter than full step which is in turn quieter than wave step patterns.
They only rotate as fast as you send pulses. There is an upper limit after which the motor rotation can't keep up with the pulses and 'locks up'.
I'm using this diagram , repeated this 4 times for my tests
I'm using DRV8825 drivers
datasheet stepper: https://nl.reprapworld.be/datasheets/SL42S247A.pdf
Thanks for the info.
Stepper data;
Using the DRV8825, do you have the current limit set for the 1.8A per phase?
What are you using for the 12V power supply?
You need to use microstepping to get the quietest and most reliable performance from a stepper. I'd suggest trying x8 or x16 microstepping.
Its essential to use speed ramping with all but the tiniest steppers, so AccelStepper library is a good place to start as it does this for you.
