Lounge LED controller Pro is a RGB LED controller which can be used to make your own programs for RGB LED strips. This will make your friends say "I want that!"
1 arduino Mega
1 W5100 ethernet shield
1 RGB Amplifier ($3 on ebay) or 3 N-channel MOSFETs such as the STP16NF06
1 RGB LED strip ($15 for 5m on ebay)
some wiring
EEPROMEX Library
RTC Library
some debugging knowledge
Android app
Arduino sketch
Please, leave a comment after download / install.
Favorites
4 favorites buttons
can't be removed
can't be long pressed
when clicked the program stops and the the Led will fade into the selected color in approximately 500 ms
two ways to store a color
1 click left circle, select a color, click the inner circle, choose favorit 1 - 4
2 select a color with the sliders, click right circle, choose favorit 1 - 4
program loop
max. 6 programed colors
colors can be removed in two ways
1 long clicking them
buttons can't be clicked
buttons have an indicator to see in what color the program is.
2 store them with color "black"
1 click left circle, select a color, click the inner circle, choose program 1 - 6
2 select a color with the sliders, click right circle, choose program 1 - 6
The program loop will play when the "play button" is clicked
two parameters can be set to control the program speed, "fade time" and "delay time"
Fade time - time to fade from one color to another (0-9 / 50ms - 3 minutes)
Delay time - time to stay in one color before fading to another (0-9 / 0ms - 3 minutes)
Left circle
color picker to select any color you want
Right circle
button to select the current color of the LED
