Hi all,
I try to understand why my Love-o-meter have this strage issue.
At the beginning of code there is a line to declare a baselineTemp const. By default the value is 20.0 and whit this value I can see this type of output:
Sensor value: 178, Volts: 0.87, degrees C: 36.91
But if I change the baselineTemp to 30.0 i see this type of output
Sensor value: 163, Volts: 0.80, degrees C: 29.59
So how it can be possible that baselineTemp value change the Sensore value that is recognize directly from the sensor?
Here my complete code also if is default from book
// utilizzo del sensore di temperatura TMP36 e di LED per indicare il grado di calore
const int sensorPin = A0;
const float baselineTemp = 30.0;
void setup(){
// con un ciclo for dichiaro i pin dei led e li inizializzo nello stato LOW
for(int pinNumber =2; pinNumber < 5; pinNumber++){
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor value: ");
Serial.print(sensorVal);
// converte le lettura ADC in tensione
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print(", Volts: ");
Serial.print(voltage);
// converte la tensione in temperatura
float temperature = (voltage - .5) * 100;
Serial.print(", degrees C: ");
Serial.println(temperature);
// in base al valore della temperatura accendiamo più o meno led
if (temperature < baselineTemp){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
} else if (temperature >= baselineTemp + 2 && temperature < baselineTemp + 4){
digitalWrite(2, HIGH);
} else if (temperature >= baselineTemp + 4 && temperature < baselineTemp + 6){
digitalWrite(3, HIGH);
} else if (temperature >= baselineTemp + 6){
digitalWrite(4, HIGH);
delay(2);
