love o meter project 3 in arduino starter kit
so i just bought the starter kit and i am stuck on project 3 the love o meter i get a error message when i try to upload it does anyone know why this is not working?
Please don’t post screen shots like that, it is not neccessary. Post your sketch by copy & pasting it from the IDE into your post using code tags (the </> icon). Do the same for error messages using the “Copy Error Messages” button on the right.
Did you change anything at all in the sketch? I suggest you copy it again from wherever you downloaded it from. You may have accidentally hit [RETURN] and split a code line into two without putting a line continuation marker on the end of the previous line.
In the middle of the if … else if … else if structure you have this line:
else if (temperature >= baselineTemp + && temperature < baselineTemp + 4) {…
I think you’ve got a number missing. It should be something like this:
else if (temperature >= baselineTemp + 2 && temperature < baselineTemp + 4) {…
EDIT
I can also see a line
digitalWrite(3, LOW):
that should be
digitalWrite(3, LOW);
(it needs a semicolon, not a colon at the end).
oke you were right about the 2 i missed that. but now it gives this message
Arduino: 1.7.11 (Windows 8.1), Board: "Arduino Uno"
sketch_oct10c.ino:1:25: error: expected ',' or ';' before ':' token
sketch_oct10c.ino: In function 'void loop()':
sketch_oct10c.ino:14:3: error: expected ';' before 'Serial'
sketch_oct10c.ino:22:20: error: 'baselineTemp' was not declared in this scope
Error compiling.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
When you compile some code you didn't post. All we can suggest, then, is that you look real close at line 1. It would be very unusual to see a : on line 1 of any sketch.
oh i found the solution i forgot an other ; and now it works thanks for the help
