love o meter
I really don’t get what the problem is… could some one explain it ?
thanks
const int sensorPin = A0;
const float baselineTemp = 22.0;
for(int pinNumber = 2; pinNumber < 5; PinNumber++){
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
int sensorVal= analogRead(sensorPin);
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
float voltage =(sensorVal / 1024.0) * 5.0;
Serial.print(", Volts:");
Serial.print(voltage);
Serial.print(", degrees C: ");
float temperature = (voltage - .5) * 100;
Serial.println(temperature);
if (temperature < baslineTemp) {
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
} else if (temperature >= baselinetemp + 2 &&
temperature < baslinetemp + 4){
digitalWrite(2, HIGH);
} else if (temperature >= baselinetemp + 4 &&
temperature < baslinetemp + 6){
digitalWrite(3, HIGH);
else if (temperature >= baselinetemp + 6){
digitalWrite(4, HIGH);
delay(1);
Arduino: 1.6.1 (Windows 7), Board:“Arduino Uno”
Build-opties gewijzigd, alles wordt opnieuw gebuild
sketch_mar15b.ino: In function ‘void setup()’:
sketch_mar15b.ino:9:39: error: ‘PinNumber’ was not declared in this scope
sketch_mar15b.ino: In function ‘void loop()’:
sketch_mar15b.ino:32:19: error: ‘baslineTemp’ was not declared in this scope
sketch_mar15b.ino:37:27: error: ‘baselinetemp’ was not declared in this scope
sketch_mar15b.ino:38:15: error: ‘baslinetemp’ was not declared in this scope
Fout bij compileren.
Dit rapport zou meer informatie hebben met
“Tijdens de compilatie uitgebreide uitvoer weergeven”
ingeschakeld in Bestand > Voorkeuren.
BodhiDavina:
Any problem with reading error messages?
Or just a problem with understanding error messages?
Check spelling!
If you just declare ‘int pinNumber’ (small letter ‘p’) you cannot use ‘PinNumber’ (capital letter ‘P’) in your code!
The C programming language is case sensitive!
Double check spelling
thanks for the help, problem solved. I didn't knew programming is case sensitive. Just started yesterday :P
