I had several errors, but the last one I can't figure out. I looked at the youtube video but it the sketch is different from the book i purchased and cannot find anything on it. Any help is appreciated. The errors are at the bottom. Thanks!
const int sensorPin = A0;
const float baselineTemp = 20.0;
Serial.begin(9600);//open a serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value:");
Serial.print(sensorVal);
//convert the ADC reading to voltage
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print(", Volts:");
Serial.print(voltage);
Serial.print(",degrees C:");
//convert the voltage to temperature in degrees
float temperature = (voltage - .5) * 100;
Serial.print1n(temperature) ;
if(temperature < baselineTemp){
digitalWrite(2,LOW)
digitalWrite(3,LOW)
digitalWrite(4,LOW)
}esle if(temperature >= baselineTemp+2 &&
temperature < baselineTemp+4){
digitalWrite(2,HIGH);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
}else if(temperature >= baselineTemp+4 &&
temperature < baselineTemp+6){
digitalWrite(3,HIGH);
}else if(temperature >= baselineTemp+6){
digitalWrite(4,HIGH);
delay(1);
LoveMeter.ino: In function 'void loop()':
LoveMeter:22: error: 'class HardwareSerial' has no member named 'print1n'
LoveMeter:25: error: expected ';' before 'digitalWrite'
LoveMeter:27: error: 'esle' was not declared in this scope
LoveMeter:27: error: expected ';' before 'if'
LoveMeter:32: error: 'else' without a previous 'if'
LoveMeter.ino: At global scope:
LoveMeter:45: error: expected declaration before '}' token
