Hi all,
arduino IDE 2.0.1 doesn't compile M5Stack_LovyanLauncher sketch on M5Stack Basic with this error:
(this is only the "red" part of the output)
In file included from C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\LovyanLauncher.ino:43:
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h: In member function 'void WiFiWPS::wpsInitConfig()':
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h:23:16: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
wps_config.crypto_funcs = &g_wifi_default_wps_crypto_funcs;
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h:23:32: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h: In member function 'virtual bool WiFiWPS::setup()':
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h:100:37: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
onevent = WiFi.onEvent(WiFiEvent);
In file included from C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFiSTA.h:28,
from C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFi.h:32,
from c:\Users\Documents\Arduino\libraries\M5Stack_TreeView\src/MenuItemWiFiClient.h:4,
from C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\LovyanLauncher.ino:31:
C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFiGeneric.h:159:21: note: candidate: 'wifi_event_id_t WiFiGenericClass::onEvent(WiFiEventCb, arduino_event_id_t)' <near match>
wifi_event_id_t onEvent(WiFiEventCb cbEvent, arduino_event_id_t event = ARDUINO_EVENT_MAX);
C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFiGeneric.h:159:21: note: conversion of argument 1 would be ill-formed:
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h:100:37: error: invalid conversion from 'void (*)(arduino_event_id_t, system_event_info_t)' to 'WiFiEventCb' {aka 'void (*)(arduino_event_id_t)'} [-fpermissive]
C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFiGeneric.h:161:21: note: candidate: 'wifi_event_id_t WiFiGenericClass::onEvent(WiFiEventSysCb, arduino_event_id_t)' <near match>
wifi_event_id_t onEvent(WiFiEventSysCb cbEvent, arduino_event_id_t event = ARDUINO_EVENT_MAX);
C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\WiFi\src/WiFiGeneric.h:161:21: note: conversion of argument 1 would be ill-formed:
C:\Users\Documents\Arduino\libraries\M5Stack_LovyanLauncher\LovyanLauncher\src\WiFiWPS.h:100:37: error: invalid conversion from 'void (*)(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void (*)(arduino_event_t*)'} [-fpermissive]
Multiple libraries were found for "SD.h"
Used: C:\Users\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\SD
Not used: C:\Users\AppData\Local\Arduino15\libraries\SD
exit status 1
Compilation error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
all the libraries are up to date....
I could upload the code with M5burner, but I need to modify the clock of the sd card in M5Stack.cpp from 40Mhz to 10Mhz to work with M5stack basic....
some tips?
tnks a lot
