Low-Cost Decluttering my makerspace.
I love to tinker and had many devices and instruments, that I needed to fetch from my drawer, and connect them individually whenever I needed them, ending up with a really cluttered workspace full of mains adapters and wires running everywhere.
So I decided to step back and take a day to declutter everything and put the same devices together, sharing the power supply whenever it makes sense.
I ended up with two electric connection boxes, containing all my devices in a convenient way for an everyday use:
The lower Box contains:
-1 x 24V-5A mains adapter from an older laptop
-1 x DPS3005 digital power supply 0...23V 5A
-1 x T12 temperature controlled soldering iron (Hakko clone)
-1 x buck converter 24V to 19V
The 230 V from my mains comes with earthing, which is connected over a 68K resistor to the yellow ESD protection socket.
The 24V from the mains adapter is going to a pair of banana sockets (green and black) from there it feeds the electronic power supply and the soldering iron, and the buck converter.
The output of the digital power supply goes to a pair of banana sockets red and black and the output of the buck converter goes to a barrel socket ( this one can be used to charge a notebook, or feeds my Dremel grinding tool. )
The upper Box contains
1 x 5V 3A mains adapter from a salvaged device ( can't remember what it was)
1 x DSO 201 pocket oscilloscope (cheap, but it bitterly lacked an AC-DC switch)
The 5V goes to a pair of a banana sockets and to a USB socket to charge various devices.
It also feeds over a mini-USB plug the DSO 210 (removable) mini oscilloscope, that is fixed onto the box with Velcro pads. The MCX probe input goes to an AC/DC switch to a decent BNC socket to use a regular oscilloscope probe. the signal goes also to a pair of banana sockets, that enables connecting a voltmeter so I can simultaneously measure the DC level with a multimeter and get an AC-decoupled picture of the signal overs the oscilloscope.
Last but not least: The power supply from the lower box is earthed, but the instruments of the upper box are floating, so I will not get weird ground loops.
:wink:
I now have a really decluttered maker-workspace and have practically all my daily used instruments always ready in a minimum of space.
Looks Great! I have a feeling it will be cluttered in a few months with new equipment (that would be good).
