Low frequency selection to period translation / Resolution
Hi. Part of the GUI in my code I am designing consists of a rotary knob and a display where user can select a frequency in the continuous range from 1Hz to 500Hz. Need to choose a step yet (eg 5/10Hz) but the fact doesn't change.
Obviously in the code I need to handle with the period related to the selected frequency.
I use the internal 8bit timer-0 with clkI/O/64 (from prescaler) that is 1 tick every 4us running at 16MHz.
Setting the OCR0A to 249 gives me a neat 2,0003ms period. So every ISR call related it increments every 1ms a variable that in loop once reached the exact value (e.g. 10ms 100Hz) triggers the event. That solves me also the problem for dealing with low frequencies.
This obviously works fine for frequency that have integer division result.
if user selects for example 140Hz that gives me the period of 7,14 ms I am stuck.
So I could reduce the OCR0A value to 24 giving me 10 times more the ISR call but then I have to increment the size of variables especially for low frequencies.
I need a formula that converts me a frequency into the right milli /us period to obtain the right resolution.. maybe from 1 to 20Hz in a 1-Hz step and from 20 to 500 in 10Hz step.
Best regards
t = 1/f
So
const unsigned long US_PER_SEC = 1000000;
unsigned long interval = US_PER_SEC / frequency;
I think.
I do not have 1us resolution. 4us so should I use 4us_per_sec = 250000?
inputting 340Hz it gives me 757,57 I cannot handle....
micros() has 4 uS resolution, but it doesn't change the value that you pass to it. The low 2 bits are just not used.
I have no idea why you can't handle that. Can you explain?
it will count every 4us 754, 755, 756, 757 ... 758. So I have not effectively the 340Hz user has selected previously indeed
No.
Why not?
Because it counts microseconds. Look it up in the documentation.
Rather than counting interrupts, you can have Timer0 generate the output frequency directly.
Start by calculating how many clock ticks per half cycle:
16 000 000 / 1 / 2 = 8 000 000
16 000 000 / 500 / 2 = 16 000
Then you calculate what minimum prescale value will get that down to 256 counts (maximum count on an 8-bit timer):
8 000 000 / 256 = 31250 (too big)
16 000 / 256 = 62.5 (Use prescale = 64)
The highest available prescale is 1024 so the lowest frequency Timer0 can reach is 30.5175 Hz. You could use software for frequencies under 30 Hz (under 32768 microseconds) and hardware for frequencies from 30 Hz down to 1 Hz.
