hello, when i excute my code i get this error message.
Global variables use 1555 bytes (75%) of dynamic memory, leaving 493 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
How do i fix it? Here is my code :
#include "RTClib.h"
#include "DHT.h"
#include <SD.h>
#include <SPI.h>
RTC_DS1307 rtc; //--> Initialize RTC_DS1307
#define DHTPIN 2 //--> Arduino pin connected to DHT11 Pin Out
#define DHTTYPE DHT11 //--> The type of DHT sensor used
DHT dht(DHTPIN, DHTTYPE);
File myFile; //--> File Initialization
const int chipSelect = 4; //--> chipSelect (CS) Pin
unsigned long previousMillis = 0; //--> will store last time was updated
const long interval = 1000; //--> interval (1000 = 1 second)
Serial.println("Initializing RTC DS1307...");
delay(100);
//----------------------------------------------Initializing RTC DS1307
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
Serial.println("Successfully Initializing the RTC DS1307");
Serial.println("Starting to run RTC DS1307...");
delay(100);
//----------------------------------------------Checks whether the DS1307 RTC can be run or not
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled (Set the time and date based on your computer time and date)
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); //-> If that doesn't work, use this line of code outside of "if (! rtc.isrunning())"
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
//----------------------------------------------Set the Date and Time on the DS1307 RTC
//Serial.println("Setting the Date and Time...");
//rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); //-> Use this line of code if it doesn't work in "if (! rtc.isrunning())"
//rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
//delay(100);
//Serial.println("Successfully Setting Date and Time");
//Serial.println();
// If the time and date are successfully set, then deactivate the code line (make the code a comment), then re-upload the code.
// if not done then the time and date will return to the beginning when it was set when arduino is reset or restarted.
Serial.println("Successfully running RTC DS1307");
delay(100);
//----------------------------------------------Starting up the DHT11 Sensor
Serial.println("Start DHT11");
dht.begin();
delay(100);
//----------------------------------------------Initializing Micro SD Card
Serial.println("Initializing Micro SD Card...");
delay(100);
if (!SD.begin(chipSelect)) {
Serial.println("Initialization failed!");
while (1);
Serial.println("Successfully Initializing Micro SD Card");
delay(100);
//___________________________________________________________________________________Millis to update the Date, Time, Temperature and Humidity
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
DateTime now = rtc.now(); //--> Get or update the Date and Time
//----------------------------------------------Get or update Temperature and Humidity Values
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
int h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
//----------------------------------------------Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read Data from DHT sensor!");
return;
//___________________________________________________________________________________Conditions for writing data to a Micro SD Card
// Data Date, Time, Temperature and Humidity will be written to the Micro SD Card if Seconds are worth 0,5,10,15,20 and so on
if (now.second() %5 == 0) {
Serial.println("----");
//----------------------------------------------Printing Date and Time to Serial Monitor
Serial.print(now.day(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.year(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//----------------------------------------------Printing Temperature and Humidity Values to Serial Monitor
Serial.print("Temperature : ");
Serial.print(h);
Serial.print(" | Humidity : ");
Serial.println(t);
//___________________________________________________________________________________Write to Micro SD Card
//----------------------------------------------Opening files that have been specified on the Micro SD Card
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("DHT11Log.txt", FILE_WRITE);
//----------------------------------------------Writing Data to the specified file on the Micro SD Card
// if the file opened okay, write to it:
if (myFile) {
Serial.println("Writing to DHT11Log.txt...");
//----------------------------------------------Writing Date Data to Micro SD Card
myFile.print(now.day());
myFile.print("-");
myFile.print(now.month());
myFile.print("-");
myFile.print(now.year());
myFile.print(","); //--> Write the delimiter between the data in the form of a comma character to the Micro SD Card
//----------------------------------------------Writing Time Data to Micro SD Card
myFile.print(now.hour());
myFile.print(":");
myFile.print(now.minute());
myFile.print(":");
myFile.print(now.second());
myFile.print(t); //--> Writing Temperature Data to Micro SD Card
myFile.println(h); //--> Writing Humidity Data to Micro SD Card
myFile.close(); //--> close the file
Serial.println("Successfully writing Data to Micro SD Card");
Serial.println("Error opening DHT11Log.txt"); //--> if the file didn't open, print an error
