Low memory available, stability problems may occur.
How to reduce the memory use
in the program
This is the program
#include "LedControl.h"
#include <math.h>
#define NBR_MTX 2
LedControl lc=LedControl(12,11,10, NBR_MTX);
int n[11][8][8] = {{
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,1,1,1,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,1,0,0,0,0,0,0},
{1,1,1,1,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,1,1,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{1,1,1,1,0,0,0,0},
{1,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,0,0,0,0,0},
{1,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{1,1,1,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,0,1,0,0,0,0,0},
{0,1,0,0,0,0,0,0},
{0,1,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0},
{1,0,0,1,0,0,0,0},
{1,0,0,1,0,0,0,0},
{0,1,1,1,0,0,0,0},
{0,0,0,1,0,0,0,0},
{0,1,1,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0}
const int LRin = A0;
const int UDin = A1;
bool blinkCandy = true; //switch every loop to blink candy.
int moveDir = 0; //0 = right, 1 = up, 2 = left, 3 = down.
int currMoveDir = 0;//Used to keep track of actual current dir, not just last set during a cycle
int length = 2; //Starting length.
int last[64][2]; //Matrix with enough room for one snake to use all 64 LEDs
int x = 2; //Start pos
int y = 2; //start pos
int lastId = 0; //The position of the snake prevoius step.
bool collision = false; //Set to true if collision.
bool incLength = false;
int candyPos[2]; //Holds the position of the candy.
bool candyOnScreen = false;
int speed = 200;
Serial.begin (9600);
for(int i = 0; i < 64; i++){ //set all positions outside the screen.
last*[0] = -1;*
_ last*[1] = -1;_
_
}_
_
//Set up display*_
* for (int i=0; i< NBR_MTX; i++){
_
lc.shutdown(i,false);_
_ / Set the brightness to a medium values /_
_
lc.setIntensity(i,10);_
_ / and clear the display /_
_
lc.clearDisplay(i);_
_
}_
_
}_
int looper = 0;
_
looper++;_
_
looper = looper % speed;_
_
CheckMove();_
_
if(looper==0) DoMove();_
_
if(looper==0) checkCollision();_
_
if(collision) {_
_
GameOver();_
_
}_
_
candyCollision(); //Check if candy has been eaten*_
* while(!candyOnScreen) createCandy(); //radnomize new candy position. Keep going until a valid position is set*
* if(looper % 100 == 0) candyBlink();*
* delay(1);*
void GameOver(void){
* while(1){*
* lc.clearDisplay(0);*
* delay(100);*
* PS(length-2);*
* delay(500);*
void PS(int a){
* int nr1;*
* int nr2;*
* if(a > 10){*
* nr1 = a / 10;*
_ nr2 = a - (nr1 * 10);
* else if(a==10){*
* nr1 = 1;*
* nr2 = 0;*
* else{*
* digit(a, 2);*
* return;*
* digit(nr1, 0);*
* digit(nr2, 4);*
void digit(int nr1, int offset){
* for(int x1 = 0; x1 < 8; x1++){*
* for(int y1 = 0; y1 < 8; y1++){*
* if(n[nr1][x1][y1] == 1) lc.setLed(0,y1+offset,7-x1,true);*
void candyBlink(void){
* if(blinkCandy) lc.setLed(0,candyPos[0],candyPos[1],true);*
* else lc.setLed(0,candyPos[0],candyPos[1],false);*
* blinkCandy = !blinkCandy;*
void Led(int x, int y){
* if(!incLength){*
* //Turn of the last light at the tail, re arrange array so the new tail is at index 0.*
* lc.setLed(0,last[0][0], last[0][1],false);*
* for(int i = 0; i < length; i++){*
last*[0] = last[i+1][0];
last[1] = last[i+1][1];
else{
length++;
incLength = false;
last[length][0] = x;
last[length][1] = y;
lc.setLed(0,last[length][0],last[length][1],true); // turn on led for the next position of the head.
void CheckMove(void){_
* int LR = analogRead(LRin);*
* int UD = analogRead(UDin);*
* if(LR > 600 && currMoveDir != 0) moveDir = 2; //Go right, if snake is not moving left*
* if(LR < 100 && currMoveDir != 2) moveDir = 0; //Go left, if snake is not moving right*
* if(UD > 600 && currMoveDir != 1) moveDir = 3; //Go up, if snake is not moving down*
* if(UD < 100 && currMoveDir != 3) moveDir = 1; //Go down, if snake is not moving up*
void DoMove(void){
* currMoveDir = moveDir;*
* if(moveDir == 0) MoveRight();*
* if(moveDir == 1) MoveUp();*
* if(moveDir == 2) MoveLeft();*
* if(moveDir == 3) MoveDown();*
* Led(x,y);*
void IncrementLength(void){
* incLength = true;*
void MoveRight(void){
* x++;*
void MoveLeft(void){
* x--;*
void MoveUp(void){
* y--;*
void MoveDown(void){
* y++;*
void createCandy(void){
* int xR = rand() % 8;*
* int yR = rand() % 8;*
* for(int i = 0; i <= length; i++){*
if(xR == last_[0] && yR == last*[1]){
return;
candyPos[0] = xR;
candyPos[1] = yR;
candyOnScreen = true;
lc.setLed(0,xR,yR,true);
void candyCollision(){
if(last[length][0] == candyPos[0] && last[length][1] == candyPos[1]){
IncrementLength();
void checkCollision(){
int xP = last[length][0];
int yP = last[length][1];
if(xP == -1 || xP == 8 || yP == -1 || yP == 8){
collision = true;
return;
else{
if(last[0] == xP && last[1] == yP){
collision = true;
return;
}*_
How to reduce the memory.
  1. do not hijack threads.
  2. use program memory for fixed arrays
  3. learn how to program properly
  4. learn how to post code on this forum by reading the obscurely named threats "how to use this forum"
  5. do not hijack threads
  6. do not higack threads.
  {0,0,0,0,0,0,0,0},
  {0,1,1,0,0,0,0,0},
Using over 700 bytes of precious RAM to store 88 bytes of data that doesn't need to be in RAM anyway is plain silly.
AWOL:
{0,0,0,0,0,0,0,0},
  {0,1,1,0,0,0,0,0},
It's double as it's a 3 dimensional array of integers.
Change these to byte, not int, and store as 1 byte per row:
  {0,0,0,0,0,0,0,0}, // 0b00 or 0x00
  {0,1,1,0,0,0,0,0}, // 0b01100000 or 0x60
  {1,0,0,1,0,0,0,0}, // 0b10010000 or 0x90
  {1,0,0,1,0,0,0,0}, // 0x90
  {0,1,1,0,0,0,0,0}, // 0x60
  {0,0,0,0,0,0,0,0}  //0x00
Go from 64 ints/128 bytes down to just 8 bytes
