"Low memory available" warning when compiling sketch
I have got an issue regarding tensorflowlite library
Could you please suggest how to proceed?
It's a warning so your application might or might not work.
You will have to show your code to get any useful advice.
#include <Arduino_LSM9DS1.h>
#include "TensorFlowLite.h"
#include "fallmodel.h"
#include "tensorflow/lite/micro/kernels/micro_ops.h"
#include "tensorflow/lite/micro/micro_mutable_op_resolver.h"
#include "tensorflow/lite/micro/testing/micro_test.h"
#include "tensorflow/lite/micro/micro_error_reporter.h"
#include "tensorflow/lite/micro/micro_interpreter.h"
#include "tensorflow/lite/schema/schema_generated.h"
#include "tensorflow/lite/version.h"
#include <Arduino.h>
#include <ArduinoBLE.h>
#define RED 22
BLEService fallService("5321");
BLEBoolCharacteristic fallDetectionBool("0001", BLERead | BLENotify);
tflite::MicroErrorReporter tflErrorReporter;
const tflite::Model* tflModel = nullptr;
tflite::MicroInterpreter* tflInterpreter = nullptr;
TfLiteTensor* tflInputTensor = nullptr;
TfLiteTensor* tflOutputTensor = nullptr;
const int tensorArenaSize = 32 * 1024;
uint8_t tensorArena[tensorArenaSize];
float y_pred;
int arrayIndex = 0;
float kTargetHz = 31.25;
int skipCounter = 1;
int sampleEveryN;
boolean dataFull = false;
const int buttonPin = 12;
const int notificationPin = 8;
boolean buttonState;
boolean currentButtonState;
boolean lastButtonState;
boolean buttonPressed;
unsigned long lastDebounceTime;
unsigned long lastFallTime;
boolean fell;
  // initialize serial communication at 9600 bits per second:
  delay(7000);
  tflModel = tflite::GetModel(model);
  if (tflModel->version() != TFLITE_SCHEMA_VERSION) {
    Serial.println("Model schema mismatch!");
    while (1);
  static tflite::MicroMutableOpResolver<5> resolver;  // NOLINT
  resolver.AddMaxPool2D();
  resolver.AddConv2D();
  resolver.AddFullyConnected();
  resolver.AddSoftmax();
  resolver.AddReshape();
  tflInterpreter = new tflite::MicroInterpreter(tflModel, resolver, tensorArena, tensorArenaSize, &tflErrorReporter);
  // Allocate memory for the model's input and output tensors
  TfLiteStatus allocate_status = tflInterpreter->AllocateTensors();
  if (allocate_status != kTfLiteOk) {
    Serial.println("AllocateTensors() failed");
    return;
  // Get pointers for the model's input and output tensors
  tflInputTensor = tflInterpreter->input(0);
  tflOutputTensor = tflInterpreter->output(0);
  if (!IMU.begin()) {
    Serial.println("Failed to initialize IMU");
  if (!BLE.begin())
    Serial.println("starting BLE failed!");
    while (1);
  //set up accelerometer range and frequency
  IMU.setAccelFS(3);
  IMU.setAccelODR(3);
  IMU.setContinuousMode();
  sampleEveryN = static_cast<int>(roundf(IMU.getAccelODR() / kTargetHz));
  //setting up BLE
  String BLEAddress = BLE.address();
  Serial.println ("Address: " + BLEAddress);
  BLE.setDeviceName("Fall Detector");
  BLE.setAppearance(1088);
  BLE.setLocalName("BLE Fall Detection");
  BLE.setAdvertisedService(fallService);
  fallService.addCharacteristic(fallDetectionBool);
  BLE.addService(fallService);
  fallDetectionBool.writeValue(false);
  BLE.advertise();
  Serial.println("Looking for connections");
  BLE.setEventHandler(BLEConnected, bleConnectHandler);
  BLE.setEventHandler(BLEDisconnected, bleDisconnectHandler);
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(notificationPin, OUTPUT);
  Serial.println("Initialized");
  BLEDevice central = BLE.central();
  while (IMU.accelerationAvailable()) {
    float aX, aY, aZ;
    IMU.readAcceleration(aZ, aY, aX);
    //skipping to match the frequency of the data used to train the model
    if (skipCounter != sampleEveryN) {
      skipCounter++;
      continue;
    tflInputTensor->data.f[3 * arrayIndex] = aX/10;
    tflInputTensor->data.f[3 * arrayIndex + 1] = aY/10;
    tflInputTensor->data.f[3 * arrayIndex + 2] = aZ/10;
    //x[arrayIndex] = aX;
    //y[arrayIndex] = aY;
    //z[arrayIndex] = aZ;
    skipCounter = 1;
    arrayIndex++;
    if (arrayIndex > 74) {
      dataFull = true;
  currentButtonState = !digitalRead(buttonPin); //read state of button
  if (currentButtonState != lastButtonState) {
    lastDebounceTime = millis();
  if (millis() - lastDebounceTime > 50) {
    if (currentButtonState != buttonState) {
      buttonState = currentButtonState;
      if (buttonState == LOW) {
        buttonPressed = true;
        Serial.println("button pressed");
  lastButtonState = currentButtonState;
  if (dataFull) {
    // Serial.println(tflInputTensor->data.f[0]);
    TfLiteStatus invokeStatus = tflInterpreter->Invoke(); //run the model
    arrayIndex = 0;
    dataFull = false;
    if (invokeStatus != kTfLiteOk) {
      Serial.println("invoke failed");
    Serial.println("");
    y_pred = tflOutputTensor->data.f[1]; //model's prediction on accel data
    Serial.println(y_pred);
    if (y_pred > 0.7) {
      //fall has been detected by the model
      Serial.println("Fall");
      lastFallTime = millis();
      fell = true;
      digitalWrite(RED, HIGH);
  if (fell) {
    //options after a fall is dected
    if (millis() - lastFallTime > 30 * 1000) {
      //alerting phone app as no button press for 30 seconds after fall detected
      if (central) {
        fallDetectionBool.writeValue(true);
      digitalWrite(RED, LOW);
      fell = false;
    else if (buttonPressed) {
      //button is pressed during initial time period and fall alert is deactivated
      if (central) {
      fell = false;
    else {
      //initial 30 second time period when buzzer is on
    //if the button is pressed when a fall is not detected activate the fall timer
    fell = true;
  buttonPressed = false;
void bleConnectHandler(BLEDevice central) {
  Serial.println("connect");
void bleDisconnectHandler(BLEDevice central) {
  Serial.println("disconnect");
Will there be any problem with that precompiled library not found statement?
No. The "Precompiled library in ... not found" messages are telling you that the library developers specified in the metadata that Arduino build system should check for a precompiled archive of the library, but such an archive was not found. In this case, the build system falls back to compiling the library from the source code. So you will not have any problems with your program as a result of this.
The reason there was an attempt to precompile the library is because this is a very big library that takes a relatively long time to compile from source. So if Arduino precompiles it in advance, that reduces the time it takes for the user's sketch to compile the first time (after that the compiled library is cached on your computer so subsequent compilations will be just as fast anyway).
I see that there are versions of the library with a "-precompiled" suffix on the version number for previous releases of the library, but for some reason there is not one for the latest "2.4.0-ALPHA" release of Arduino_TensorFlowLite. I remember some people had problems with precompiled libraries only working in combination with the specific version of the Arduino boards platform ("Arduino Mbed OS Nano Boards" in this case) they were compiled for. So maybe Arduino decided that it was not beneficial in the end, but forgot to change the metadata of the library so that the build system would skip this precompiled archive check?
