Low memory code just to run one servo
Hi All,
[didn't think this was the motor forum as it's not high power/current/voltage - mods please move if it's better placed there.]
Deconstructed the Servo Library to run a single servo off a Nano.
The code below runs a single TowerPro Servo with minimal memory use. (812 bytes of flash memory as opposed to 2400-ish). Servo was a Chinese clone of a TowerPro 9G.
Just putting this up for reference.
Regards,
A
//datasheet http://www.ee.ic.ac.uk/pcheung/teaching/DE1_EE/stores/sg90_datasheet.pdf
#define servoPin 12  //Digital pin that the Servo Control Signal Wire is connected to
int servo_pos;
pinMode(servoPin,OUTPUT);
digitalWrite(servoPin,HIGH);delayMicroseconds(1485);//1485 microseconds = 90*
servo_pos=45;//<-- arbitrary position - set this with code
servo_pos=constrain(servo_pos,0,180); // constrain to semicircle
servo_pos=map(servo_pos,0,180,500,2470); //500, 2470 are delays in microsec corresponding to 0* & 180*
digitalWrite(servoPin,HIGH);delayMicroseconds(servo_pos); //send high pulse corresponding to servo position
digitalWrite(servoPin,LOW);delayMicroseconds(20000-servo_pos); //balance of 20000 microseconds = 50Hz
//I was going to use millis command to set cycles, but the above worked acceptably
Think about trying it a little differently..
unsigned int endTime;
setup() {
  doSetupThings();
 endTime = millis();
void loop(void) {
  if (millis()>endTime) {                       // If it's time for a pulse..
     servo_pos=map(servo_pos,0,180,500,2470);   //500, 2470 are delays in ms
     digitalWrite(servoPin,HIGH);               //send high pulse corresponding to servo position
     delayMicroseconds(servo_pos);              // Take a smoko..
     digitalWrite(servoPin,LOW);                // Pulse complete.
     endTime = millis()+18;                     // Set up for next pulse.
now you have the lion's share of your time left over to see what the user wants. Possible check the serial input, look at some sensors..
-jim lee
I like your style, Jim.
Thanks,
A
