I am trying to build a micro servo robot arm and I a getting a Low Memory message.
Please help.
I get the message with the dfrobot Arduino Uno R3 and the Arduino Mega2560
I have attached the program
Micro Servo Robot
Thanks so much, Please email me so I get your message, I'm not good in these forums.
Do those arrays have to be of the int (2 byte) data type? What is the largest number that an element of those arrays will be? If the numbers are less than 256 you could make them byte arrays and save 720 bytes.
Sketch uses 8092 bytes (25)% of the program storage space. Maximum is 322256 bytes.
Global variables use 1864 bytes (91)% of dynamic memory, leaving 104 bytes, local variables.
Max is 2048.
I thought I would be ok with the Mega 2560 because it has 8K of sram.
I found another program for the Micro Servo Robot Arm on the site below but when I compile it I get this message
"mode was not declared in this scope"
Here's the code I cut and pasted in the IDE
Does anyone see the problem, any help would be greatly appreciated.
int PosCount = 0; // to count number of positions increased when button pressed
int PosCountMax = 0; // number of positions recorded when double button push initiates replay mode int PosReached = 0; // used to check that arm has moved from one recorded position to next position void setup() { for(int i = 0; i <100 ; i++ ){ for(int p = 0; p <4 ; p++ ){ ArmPos*[p] = -1; } } pinMode(PinButton1 , OUTPUT); digitalWrite(PinButton1 ,LOW); pinMode(PinButton2, INPUT_PULLUP); // I have made a small change here due to problem using some Arduinos //attachInterrupt( digitalPinToInterrupt(PinButton2),ButtonPress , LOW ); // digitalPinToInterrupt(PinButton2) may not be defined! attachInterrupt( 1,ButtonPress , LOW ); // interupt to capture button presses // attach servos to relervent pins on arduino nano Arm0Servo.attach(12); // grip 90 to 180 open limits of servo movement Arm1Servo.attach(11); // elbow to 130 up Arm2Servo.attach(10); // shoulder 10 to 50 down Arm3Servo.attach(9); // turn 0 to 180 right }* void loop() { switch(mode){ case 1 : // program robot arm. 1 press to remember position. 2 presses to progress next case 2 replay mode // analogRead(pin) that reads poteniometers on training arm PosArm[0] = map(analogRead(14),480,1024,180,90); // map (480,1024 value from potentiometer to 180,90 value sent to servo) PosArm[1] = map(analogRead(15),180,1000,130,10); PosArm[2] = map(analogRead(16),950,400,80,10); PosArm[3] = map(analogRead(17),0,1024,180,10); MoveArm(); // call method if(buttonPress == 1){ // flag set by interupt when button is pressed buttonPress = 0; // reset flag if( millis() > (lastButtonPressTime + 1000)){ // only one button press in one secound // record position of arm PosArm to array[100][] of armpositions ArmPos[PosCount][0] = PosArm[0]; ArmPos[PosCount][1] = PosArm[1]; ArmPos[PosCount][2] = PosArm[2]; ArmPos[PosCount][3] = PosArm[3]; if( PosCount < 100) { // stop recording if over 100 positions recorded (memory limitations) PosCount++; } }else{ // more than one button press mode = 2; // go to next phase PosCountMax = PosCount; // set number of arm positions recorded PosCount = 0; // reset count ready to read arm position array from begining } lastButtonPressTime = millis(); } break; case 2 : // read arm position array PosReached = 0; for(int i = 0; i <4 ; i++ ){ //adjust servo positions // we move the servos in small steps and the delay(20) makes arm motion smooth and slow if( PosArm > ArmPos[PosCount]) PosArm = PosArm - 1; // if actual position is greater than requird position reduce position by 1 if( PosArm < ArmPos[PosCount]) PosArm = PosArm + 1; // if actual position is less than required position value increase position valuue by 1 if( PosArm == ArmPos[PosCount]) PosReached++; // check if servo has reached required position/angle } if(PosReached == 4) PosCount++; // if all 4 servos have reached position then increase array index (PosCount)to next position in array if(PosCount == PosCountMax) PosCount = 0; // if end of array reached reset index to 0 and repeat. MoveArm(); // physically move arm to updated position, this is broken into small steps delay(20); // pause between moves so over all motion is slowed down break; default : break; } } void MoveArm() { // write arm position data to servos for (int i = 0 ; i < 4 ; i++) { if (PosArm < 5) PosArm = 5; // limit servo movement to prevent hitting end stops if (PosArm > 175) PosArm = 175; // servo.write limited 5 - 175 } Arm0Servo.write(PosArm[0]); Arm1Servo.write(PosArm[1]); Arm2Servo.write(PosArm[2]); Arm3Servo.write(PosArm[3]); } void ButtonPress(){ // interupt to capture button press if(micros() > (bounceTime + 3000)){ // debounce timer bounceTime = micros(); // ingnore interupts due to button bounce buttonPress = 1; // flag for button pressed } }
Hello I reposted this because I wanted to reflect the correct subject of my programming problem.
I found another program for the Micro Servo Robot Arm on the site below but when I compile it I get this message. Any help would be greatly appreciated.
int PosCountMax = 0; // number of positions recorded when double button push initiates replay mode int PosReached = 0; // used to check that arm has moved from one recorded position to next position void setup() { for(int i = 0; i <100 ; i++ ){ for(int p = 0; p <4 ; p++ ){ ArmPos[p] = -1; } } pinMode(PinButton1 , OUTPUT); digitalWrite(PinButton1 ,LOW); pinMode(PinButton2, INPUT_PULLUP); // I have made a small change here due to problem using some Arduinos //attachInterrupt( digitalPinToInterrupt(PinButton2),ButtonPress , LOW ); // digitalPinToInterrupt(PinButton2) may not be defined! attachInterrupt( 1,ButtonPress , LOW ); // interupt to capture button presses // attach servos to relervent pins on arduino nano Arm0Servo.attach(12); // grip 90 to 180 open limits of servo movement Arm1Servo.attach(11); // elbow to 130 up Arm2Servo.attach(10); // shoulder 10 to 50 down Arm3Servo.attach(9); // turn 0 to 180 right }
void MoveArm() { // write arm position data to servos for (int i = 0 ; i < 4 ; i++) { if (PosArm < 5) PosArm = 5; // limit servo movement to prevent hitting end stops if (PosArm > 175) PosArm = 175; // servo.write limited 5 - 175 } Arm0Servo.write(PosArm[0]); Arm1Servo.write(PosArm[1]); Arm2Servo.write(PosArm[2]); Arm3Servo.write(PosArm[3]); } void ButtonPress(){ // interupt to capture button press if(micros() > (bounceTime + 3000)){ // debounce timer bounceTime = micros(); // ingnore interupts due to button bounce buttonPress = 1; // flag for button pressed } }mode
