Low pass filter for arduino avcc pin
I have found plenty of references to the need for this between Vcc and AVcc if using the analogue pins but no references as to a specific example.
So can any one give me a schematic of a suitable low pass filter for this pin? What is the cut-off frequency?
in my Atmega328 datasheet (version of 8/10) it is "Figure 23-9. ADC Power Connections" A 10mH inductor and a 100nF capacitor.
westfw: in my Atmega329 datasheet (version of 8/10) it is "Figure 23-9. ADC Power Connections" A 10mH inductor and a 100nF capacitor.
Thanks. I have an Atmega328P and the datasheet mentions but does not specify a low pass filter.
The Uno does not use a low pass filter as such, but you should at least have the 0.1µF capacitor immediately adjacent to that pin, and arguably a 10µF or larger as well.
Paul__B: The Uno does not use a low pass filter as such, but you should at least have the 0.1µF capacitor immediately adjacent to that pin, and arguably a 10µF or larger as well.
Why greater than 100nF?
http://www.atmel.com/Images/doc8444.pdf
Above include "2.9 Best practices for improving accuracy"
Ray
