Hey Guys,
I really appreciate your valuable information and comments. The reason why i think pwm control, is many hydraulic proportional valves can be controlled by pwm. When you increase or decrease frequency, position of spool changes. So hydraulic flow may be increased or decreased depends on needs. That is what i think, i wish to do. Purpose of measuring voltage gives me clues about the function of system. I think (if i am right,) when i measure 24 v that means i give %100 duty cycle, if i measure approx 12 V that means i give %50 duty cycle. I also tried this on a on-off type solenoid, pwm seems working but, since valve is not a proportional type, mid values either open valve or shuts the valve. this is because ,i think, spring behind the spool is very tough and does not allow spool position stands in mid values of extremities.
my intention to use low pass filter before solenoid, maybe it smooths the frequency values, than i can get a proper ramp function and solenoid behavior.
That is my way of thinking, maybe i am wrong?
(Note: i dont need to reverse the solenoid. Only one way. I know i can use a small mosfet but this product seems for me a heavy duty device that can stand up to 43A. This is only for safety).
rmetzner49:
The reason I didn't reply to the OP regarding the low-pass is I think it's silly. You have a huge inductor sitting there already, so all you have to do is increase the PWM frequency. The inductor is the lowpass!
After you say, i am thinking as you, also valve manufactures say, as far as i understand, some dither is good for valve efficiency and this small movements caused by pwm drive will create a dither also.
By the way as you understand, i am not an expert, so i will try this in a real proportional valve. The reason that i ask is before buying a 400 EUR valve , learning as much as i can.
Thank you again. More suggestions would be appreciated.
Best Regards.
