for my project I need a low-power unit. I oriented myself to the instruction on http://www.gammon.com.au/forum/?id=11497
The uC cames from a burned Arduino Uno (touched accidentally one pin with 12V power-wire - the Arduino stops working after 5 minutes now - do not know what exactly is broken, but it is enought time to program the uC for the barebone )
The active board consumes around 73mA, the following Sketch ("deep sleep") 58mA!!! It is both 24mA more than an normal Uno!
Values from the page (active/asleep) in mA:
Uno 49/34
Barebone 15/0.4
Without the uC connected the multimeter shows 41uA (an ADXL345 is soldered directly to the barebone, so it should be ok)
Sketch B
#include <avr/sleep.h>
void setup ()
 set_sleep_mode (SLEEP_MODE_PWR_DOWN); Â
 sleep_enable();
 sleep_cpu (); Â
} Â // end of setup
void loop () { }
May the uC has taken damage despite that it works without any restriction? Or must the error be in the soldering?
I have bought a new 328. With this one the barebone consumes (uC unprogrammed, without Arduinobootloader) about 8mA. But I do not get the bootloader installed. Seems that the broken Arduino is damaged to hard
EDIT: 10k resistor from reset to gnd is installed anyway.
The 10k resistor should goto VCC not Gnd, check the schematics again, see your same image link again even in it the reset is to the vcc so how come you have wired it wrong?
The lower level of current that you are trying to measure is either possible using a $600 Fluke or the Dave Jones uA current meter, Do you think your multimeter is that good?
also for example many multimeters like Vichy (many models of it!) are not upto mark with measuring stuff, so most probably if its a ELcheapo multimeter then dont waste your time trying to read uAmps out of it.
I know that. My goal is a low as possible standby-consumption. If the multimeter shows 70mA I know it is to much. If it shows 8mA I know that it is better. It does not matter how much it exactly is.
