Low Power RF Transceiver(433MHz-13dBm)
Can someone help me program communication between two of these Low Power RF Transceiver(433MHz-13dBm) : rhydoLABZ INDIA
using arduino uno......
It supports a plain old serial interface. So the programming is dirt simple, it's just serial programming on the Arduino.
would you be a bit more helpful
Use Serial.print(), etc.
Did you not notice the connection diagram and detailed instructions in the data sheet?
yes i did thanks
hey sorry am back.......
could u give me an example code.....
and how the connections should be
