Low quiescent current regulator? (12V -> 5V pth)
When trying to reach best efficiency, and you should when using battery power, you should not be looking at any linear voltage regulator but rather a switching regulator. The reduction from 12v to 5v using a linear regulator means that you waste more power in the regulator then the arduino board is using. The example below is of a switching regulator that will allow you the best battery running duration.
http://www.ebay.com/itm/QZO-Buck-Converter-Step-Down-Adjustable-Converter-Power-Module-Regulator-LM2596-/131143304399?pt=LH_DefaultDomain_0&hash=item1e88c004cf
