I am using the Feather Huzzah - ESP8266. I am using the onboard red LED [pin 0]. The board is powered through USB. I have done no wiring myself.
I ran the example code blink right out of the box and it seemed to perform perfectly.
Upon greater inspection it seems as though when I digitalWrite() to the onboard LED it turns on when I write LOW and turns off when I write HIGH.
A code example that produces this output is:
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(5000); // wait for 5 seconds
This code will turn off the led for one second, then it will turn on for 5 seconds. Is this correct functionality and I'm missing a key concept here or is my board configured incorrectly?
Thank you for your help.
