Hello every one , my name is Paul and this will be the first time that I will post here , although I have spend many hours reading through various posts here and thank you for every one that contributes to all the questions posted here it is always been a good point of reference for me.
My Goal:
I have a Single relay that will turn on security lights out side my house. The lights are on as special 12v / 220v relay so I just need to trigger the Relay to turn on / off the lights (for safety reasons).
There will be three inputs to turn on the lights:
- LDR sensor that will be triggered by a old cell phone that we can call (This will only accept two numbers)
- A push button switch that will turn the lights on or off depending on its state
- A Alarm relay that will turn on the lights when it is triggered and stay on for a set time after the alarm has stopped.
My Method:
I stated by building each trigger separately in a sketch and then added them together in one sketch - now I am not even close to knowing exactly what I am doing but I do understand the general logic of the coding -
I managed to get Triggers 1 and 2 working perfectly and they would behave exactly as I planned but the moment I add the Alarm trigger every thing goes a bit pear shape.
The Alarm trigger wont send the "HIGH" signal to the relay but will turn the LED on for the set time but on the triggers 1 and two the relay will go on but the LED will not stay on with the Relay to indicate that the relay is on.
Now I assume that the various codes are now interfering with each other but I cannot find the it and I hope that it is just a small piece that needs to be changed.
Can any one help?
The Code Below:
// Bits and pieces taken from all over the net to compose this code. I could not take any credit for all it and so shouldn’t any one else. Use it change it delete it as you like!!!!
// This code will run a single relay that will switch on a set of security lights. And will have 3 inputs.
// 1) LDR that will be triggered by a old Cell phone (Phone will be programed to accept only two numbers)
// 2) Push Button switch located in the house
// 3) Alarm that will turn on the security lights when it is triggered
const int LDR = A0; // The LDR that monitors the cell phone screen
const int Relay = 2; // The Relay that Controles the Lights
int pinButton = 8; // The main switch that will be wall mounted (Might be a "bell" Push button)
int AlarmRelay = 9 ; // The Relay that will be triggered when the alarm goes off
int LED = 13; // The Led that will show that the relay is on or off
// Values for Alarm trigger
int stateButtonAlarm ; // to Chek the state of the Alarm Relay
int ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0; // will store last time LED was updated
long OnTime = 100; // milliseconds of on-time
long OffTime = 10000; // milliseconds of how long before the light time goes off after
// VALUES for LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int previous = LOW; // the previous reading from the input pin
long time = 0; // the last time the output pin was toggled
// Values for Push Button
unsigned long LastOnTime = 0;
boolean RelayState = LOW;
int stateRelay = LOW;
int stateButton;
long debounce = 500;
pinMode (AlarmRelay,INPUT);
pinMode(pinButton, INPUT);
pinMode(Relay, OUTPUT);
pinMode (LED, OUTPUT);
Serial.begin(9600); //sets serial port for communication
// Cell Phone Switch Code
int LDRValue = analogRead(LDR); // read the value from the LDR
Serial.println(LDRValue); //prints the values coming from the sensor on the screen
// code for checking the LDR and if the phone is on
// If the screen is ON...
if(LDRValue > 400) {
// ...and it has been Less than 1 seconds since it was last seen on...
if (millis() - LastOnTime > 1000UL) {
if(stateRelay == HIGH){
stateRelay = LOW;
digitalWrite (LED , LOW);
stateRelay = HIGH;
digitalWrite (LED , HIGH);
LastOnTime = millis();
// Code for house on / off switch so that if the cell phone switch was on it can be swithed off in house
stateButton = digitalRead(pinButton);
if(stateButton == HIGH && previous == LOW && millis() - time > debounce) {
stateRelay = LOW;
stateRelay = HIGH;
time = millis();
digitalWrite(Relay, stateRelay);
delay (300) ;
previous == stateButton;
// Alarm Code - The Alarm closes a relay as it gets trigger and the siren goes off the relay will be
//closed and will be as long as the siren is activated. The security lights must stay on for a set amount of time after that siren stopped.
stateButtonAlarm = digitalRead(AlarmRelay);
if((stateButtonAlarm == HIGH) && (currentMillis - previousMillis >= OnTime))
ledState = HIGH; // Turn it on
previousMillis = currentMillis; // Remember the time
digitalWrite(LED, ledState); // Update the actual LED
digitalWrite (Relay,HIGH); // Turn on the Security Lights
else if ((stateButtonAlarm == LOW) && (currentMillis - previousMillis >= OffTime))
ledState = LOW ; // turn it on
digitalWrite (Relay,LOW); // Turn off the security lights
}[code]
