low voltage AC to square wave Arduino input
Hi Everyone,
I have a low voltage AC sign wave 4vPP and I want to feed this into a Arduino digital input as a square wave. The sign wave is the output of a crank position sensor. Can anyone suggest/post a schematic that will do this ideally using minimal components e.g. an IC. the input can be just the positive side of the wave and I will simply double it to get a RPM (attached a pic of the output)
Thanks for the help in advance
P.S. as this is a crank sensor it should not interfere with the original sinewave
feed the signal to an input of a Hex Schmitt−Trigger Inverter chip and the output to a digital pin.
groundFungus:
is it as easy as that :slight_smile: will try this, hope it works, thanks
You will have to condition the signal so that it does not go negative (below ground).
groundFungus:
What would happen if it goes negative without conditioning?
P.S. I'm OK with only detecting the positive pulse.
Steve
Vin DC Input Voltage (Referenced to GND) – 0.5 to VCC + 0.5V
From the data sheet. You must not feed a voltage lower than -0.5V to the input pin of the 74HC14. So even if you are only interested in the positive part you have to guard against the negative if it is there.
groundFungus:
That's fantastic :slight_smile: I assume that's a 10uf cap in the diagram?
Steve
I think 10uF
Might have been barking up the wrong tree, looks like it's got a digital tacho ::slight_smile: I'll let you know.
Steve
