Really need your help ! I'm trying to read a 0.7v signal when it's high and about 0.3v when it's low.
I've tried a transistor switching 5V but the base emitter voltage is too low. Ive also tried an optocoupler and again the same problem. I've tried to analog read it......but that is too slow
Can anyone assist with a suggested circuit or point me in the right direction . ANY help would be appreciated as I'm not an electronic expert but I'm trying to have some fun
Signal is coming from an SMD led. I really didn't know they could operate on such low voltages. Ive checked over and over again and it looks like the led is being driven by approx. 0.7v?
I measured across it while it was on and got 0.7v. I removed the led from the circuit and still got 0.7v. I have measured all over and cant find a higher voltage. It might be possible that there is a series resistor on the supply to this pcb.
You need to play the game - show the circuit of the device with which you are working.
I would like to if it would add value. attached is a pic. Red mark is where i removed the led.
the flexible ribbon coming in has 6 tracks. The pcb has 6 independent buttons on it and 6 independent LED's on it.......yet there is no IC's on this. It looks like it is just buttons, leds, and a few smd resistors. Really confused how this can do all that
You must not have measured it correctly. It is a matter of physics that you can not have a visible LED with a forward voltage of 0.7V. This is down to Planks constant.
