lowByte and highByte are not really byte functions
The reference page states that lowByte and highByte return a byte. This appears not to be the case.
I discovered this when making a call like:
Wire.send(lowByte(i2cdata));
if i2cdata is type int, this works fine. If i2cdata is type word, a compiler error is generated.
I am not sure exactly why but I suspect it has to do with the way lowByte and highByte are implemented in Wiring.h:
#define lowByte(w) ((w) & 0xff)
#define highByte(w) ((w) >> 8)
so what type you get from highByte and lowByte depends on what you feed them.
You can easily fix this by using (byte)lowByte(xxxx) but it is cetainly counter-intuitive.
To show this more clearly:
int d, c, a = 0xffff;
byte b;
b = lowByte(a);
c = sizeof(b);
d = sizeof(lowByte(a));
Serial.print(c,DEC);
Serial.print(" ");
Serial.println(d,DEC);
void loop(){}
produces the output:
1 2
showing that with an int argument lowByte returns an int value.
C essentially specifies that all intermediate values in calculations are of at least type 'int', which occasionally causes assorted problems with attempts at optimization. But I'm not sure why "Wire.send(lowByte(i2cdata));" would cause a compiler error (what's a "word"?); aren't arguments automagically truncated to correct size?
