lowering power consumption
hello
i need some help on calculating power consumption and how to make my circuit more efficient in terms of power usage.
i*m building a wordclock with a chronodot RTC chip to keep track of the time.
i also use 38x neopixel to light up the individual words.
(se attached picture)
and i was hopeing to run the clock on batteries for atleast a couple of months.
but the clock is useing WAY to much power to be able to do that.
i have done some research and testing today.
the arduino circuit itself uses 35mA
the neopixel*s uses around 420mA when FULLY bright white
and around 366 when they are very weak with just 1 color.
this is under normal operating conditions. with just 5-8 leds on depending on the time.
so i started thinking about dropping the neopixel and just go with normal leds or RGB leds.
so i did some more testing.
1x with 330 ohm resistor = 18mA
rgb led used a total of 53.5 mA when fully on
R=23,4 mA fully on
G=23,4 mA fully on
B=23,4 mA fully on
i could dim the rgb leds down so that the whole circuit uses around 250mA but its still to high.
they use a little less then the neopixel but not much.
Battery pack?
even if i got a 100000 mAH battery which is huge and take lots of space it still only get me around 200hours which is a little more then a week.
and in order to run the clock on batteries i need to get the power consumption to below 100mA
(atleast i think)
any suggestion on how to lower the power consumption?
or do i have to give up on the batteries and go with "wall" electricity,
and just use battery as backup?
some of my calculations could be wrong so don*t trust them 100%(only 80% hehe)
The complete guide to reducing power consumption by ATMegaxx8 processors is here.
The LEDs are the main problem, though.
Definitely go for the highest efficiency LEDs, run at a few mA each if you can, they are very bright.
Probably the biggest gain you could get is some form of motion detection and shut the display down
if noone is present.
The "problem" speaks for itself.
If you want an illuminated clock, you need a mains power supply. Simple as that.
But the PIR detector to switch it all on (including the Arduino itself) is probably a good compromise.
